The VINTAGE toolboxes of Garage Journal!
genog
Silicon Valley
I always use zip ties. they work great for this, and you won't chew up your hands.
(y)
I went into my zip tie box and found the perfect zip tie....
5/16" wide
Perfect fit
So, I removed each of the drawers (once again) on the ole Snappy cab using this method
I was able to get them out faster and is much easier than using a hacksaw blade
and indeed.....my hands didn't get chewed up :)
jreb10
Westby, WI
Here is an interesting and apparently uncommon Kennedy chest. It is a Kennedy 515 based on the catalog entry below. It has unusual pulls that are brass beneath the paint, and a Corbin lock. It is described as a Machinist's Steel Tool Case. My limited research has it appearing in catalogs in the 1920s, sometimes with a bigger brother the 519. Perhaps these chests were the precursors to the 520.
At some point in time this chest was painted but fortunately the Kennedy sticker has been retained. The sticker is a "Patents Pending" version, although I don't know what that means in terms of dating this chest. Very little information comes up on this chest when I search. Here are some photos.
My notes put the 515 in catalogs til 1924, also the last time the Oval pulls were listed as solid brass. Still Oval until 1930.
My smallest is a 516, dated at 1947 or so. The Oval and Hoop handles have both evaded me.
Nice get.
Leviton
Oregon
From a distance, buried amongst other stuff at the thrift store, this box looked promising - metal handle, reinforced corners, appropriate size - was hoping for a WWII era box.
Unfortunately... not.
However, due to the sticker on the side, I had to at least take photos.
(It had writing embossed on the side that was mostly covered by the sticker. Attached is a reversed photo taken of the inside of the box - the embossing read:
"Don't Drill It... Drive It. )
You win some, you lose some.
edit: Originally typed "WWI", meant to type "WWII".
Leviton
Oregon
First showing up in Google Books in 1949. Not awful, but not WWI.
Oh. Thanks for catching that, I meant to type WWII, not WWI. And, thanks for the ... Drive It reasearch. Never thought that would have been as old as 1949.
  • Like
Reactions: RTM
Surprised me too, the box looked older, like WWII, but didn't think the powder activated tools went back that far.
Ryan
Administrator
Boulder/Koloa
Anyone know the model of this toolbox? I'm not at all up on this stuff, but the stainless side trim makes me think 1980s... but the old logo and full width pulls make me think a little older...
  • Like
Reactions: 555
@Ryan, my Snap-on roller has that logo badge on the front, and it's a 1997, if I'm not mistaken. As Outlaw noted, the model number should be stamped on the back of the cabinet somewhere - mine is really difficult to read unless the light hits it just right.
Mintgrun
Kingston, Wa.
It also looks like my KR-558 from '71.
It's stamped in the front lower left corner.
EDIT, I just looked up the difference between the 557 and 558 and it is the width.
From google:
The main difference between the vintage Snap-on KR557 and KR558 roll cabinets is their width and footprint, as they belong to different size tiers of Snap-on's classic 1970s and 1980s friction-slide tool storage lineups. [1, 2]
Key Comparisons
FeatureSnap-on KR557 (e.g., KR557B/C)Snap-on KR558 (e.g., KR558B)
Width~32-1/2 inches~26-1/2 inches
Depth~18 inches~18 inches
Height~38 inches~37 inches
Typical Top Chest CompanionKR537 (approx. 35" wide)KR533 / KR530 (approx. 26.5" wide)
Drawer Layout7-drawer wider configuration7-drawer narrower configuration
Although there are a few references to suggest they started going metal as early as late 1945, most mfgrs of hip roof style boxes were still using leather handles through WWII, to the extent that a metal handle is still largely considered a postwar tell. Conversely, the ornate corner supports/feet started going away at the same time and the lack of them is typically a 1950s or later tell. The combination on that box strongly suggests late 1940s.
Jgaz
Good eye. A unique feature (at least I know of no other model having this) is a flip up panel in the top that would remain hidden with a work surface added.
Please post a more detailed picture preferably open. I’ve been around SnapOn boxes since the 70’s and have never heard of that feature.
Ryan
Administrator
Boulder/Koloa
Cleaned up pretty nicely with just some simple Green.
Slides are a little stiffer than I would like, so need to get some paraffin wax… otherwise, just add liners and this $150 toolbox is ready to go.
I’d really like to find another similar box to add to this one and build a workbench out of em…
