LeonardY
Cleaned, put away and flung.
Then moved everything off one wall to see how to run electrical for a mini split.
Well I can understand that. Just seeing some of your previous work, I figured you would have DIY.I intend to use this primarily as a recovery point. A recovery point failure can result in injuries or deaths. I figure letting someone certified in welding do the job makes good sense.
A man's gotta know his limitations--and it was $175, which I figure is a pretty good deal.
Watchmakers - it is another world that makes my brain hurt. I'm used to precision machining, but this requires tiny precision machining.Taking a break from working on the Dalton lathe to... working on another lathe!
It is rare to find a watchmakers lathe with the tailstock, rest, collet closer, and motor pulley, especially for what I paid for it at a tool sale over the weekend. And, as it is midweek, my wife works from home, and my shop is in the basement, so I try not to make too much noise, which means any metal working machinging needs to be done on the weekend or at night. Which means I need to work on quiet stuff during the week. So, cleaning this up is the task at hand.
What exactly am I looking at here?sleeves.
Wire wheeling the undercoating from 1973 = making my own long sleeves. It's undercoating that I've wire wheeled off the underside of the car. It's a messy job.What exactly am I looking at here?
I'm bad about not selling tools.
Wow! I thought you made some hairy looking sleeves.lolWire wheeling the undercoating from 1973 = making my own long sleeves. It's undercoating that I've wire wheeled off the underside of the car. It's a messy job.
Got some dash issues, and a bunch of previous owner wiring mishaps. I'm doin it... pulling the dash.
That wasn't so bad. Check out this heater box...
I need to do that:
And exactly for that, only I'l be soaking the core in Hydrogen Peroxide. Wasp nests...
FYI you can cut a hole in the heater box and use a shop vac to get leafy debris out in the future...
I should say I even moved the cars that I thought the limb might even graze. Weird normally I damage things before I consider this.Good thinking!![]()
I'm currently working on my backhand and wing shots.
Isn't there some kind of Presidential medal for that? Maybe Congressional?Completely new wiring harness, new monitor, 16 new brain boxes, 12 hyd cylinders, 42 hyd hoses, 12 electric motors, firmware updates on 40 things and no leaks or electrical issues. It all just worked.
I didn’t do it alone. I had close to $400/hr in helpers here lol. Little man and I were sort of the gophers if you want to give us a title. I did make all of the hyd hoses and run most of the wiring so I guess I can take some credit for some of it.Isn't there some kind of Presidential medal for that? Maybe Congressional?
Should at least get a headline (above the fold, of course) in the local rag--if any.
Local Man Completely Rebuilds And Upgrades 12-Bottom Planter, Works The First Time!
\Went up front to wait for old friends from out of town to show up. They sat five feet from me for fifteen minutes before we recognized each other. Old *****.
We were planning to spend a couple of days backcountry driving in the Brick--but torrential downpour. What to do now?
Started the "Ice melt test" for the two coolers:
I did use two 1/2 gallon milk carton blocks of ice - one in each, and now we see how fast each melts.
Coleman is 70 Qt. advertised
Pik-Nik is 72 Qt. calculated
7 hrs in. both are holding up decently, but not surprisingly, the Coleman is edging ahead.
