Ego mower problem
timm1
lagrangeville new york
I am working on a ego lm2150sp mower but not sure which part is faulty. The battery is good and after I hit the switch and pull the bail toward the handle the blade will spin. I am not getting current to the self propelled drive. The mower is a lm21550sp and it has 3 controlers. a larger one with fins on it and 2 smaller controls. The middle small controler has a green light on when you insert the battery and would appreciate any help to diagnosis the problem.
KenB
Pittsburgh, PA
Several YouTube videos on troubleshooting. Here are two
Also, powerplusparts, cutlers and partswarehouse have some exploded parts diagrams for this mower.
Ken
T
timm1
On the power plus site they sell a product that attaches to the ego self propelled board which will bypass the fuse that is soldered on the board part is ego 2830216002
txvwnut
Bedford, Texas
On the self propelled board we finally found the fuse but not sure how to remove it.
Are you sure the fuse is bad? On mine the wiring harness failed by the handle telescope locks, which is the fold point for the harness. With mine it defaulted to the slowest speed but that's to say that could be the only result of a broken wire.
gregs
Boy Scout Salute?
I'm not understanding the last message. LMAO
Zim
On a Windows computer the CTRL/ALT/Delete function to force it to reboot was known as the 3 finger salute. Google is your friend... sort of...
Gmonkee
Let us know how it goes. I’m an Ego mower owner and a bit disappointed that Ego’s business model emphasizes sales and marketing over customer support.
Ken
Ryobi, B+D homeowner stuff is all like that. Repair isn't usually an option on handheld tools. I use both but didn't expect tools for a lifetime.
T
timm1
You are right i am also working on a Wyobi push mower and I eliminated the handle lock switch and when I try touching the remaining 3 wres from the handle I get no lights or motor. I also have a bolt laying across where the bagger piece fits in and I can feel a slight magnet force that comes from the 3 wire square block that bolts to the under side of the v shape in the mower housing.
