Channellock 548
joedodge
Tampa, fl
Anyone have a lead where I can get another pair? I know they stopped making them. And I’m kinda a plier nut and would love another pair
Tools4Me
I like them too. Only option I know of right now is to keep an eye out for a nice lightly used pair on Ebay. They don't sell cheap though. Often around $40 shipped. That being said, patience might pay off in this case. The 546 plier is the 6.5" long version of the 548 (8" plier) you want. They stopped making the 546 and the 548 pliers at about the same time. I noticed a month or two ago that Channellock has the 546 plier available to buy from their website again, so maybe the 548 will come back as well.
J
joedodge
Tampa, fl
I love them as well. I found a vintage pair on eBay for $48 when looking for some diamond slip joints. I’d like a new pair eventually. They really are amazing pliers.
sparky 1971
Central Iowa
I on
I ordered these from Channellock before Epstein's Day hoping they would come in but still haven't seen them. Maybe they're on backorder for everyone right now?
I couldn't help myself and ordered a pair which showed up in less than a week. But, it was only one pair.
308guru
Just got off the phone with Channellock. Apparently they only found a small amount of these and so they're not wholesaling them. Only place you'll find them is on their website and when they're gone they're gone.
Which one? The 546 or 548?
J
joedodge
Tampa, fl
I’m interested in this as well. If I have to buy another pair of matcos to have this style I will but wanted another pair of 548
boom_bap
Idaho
546, the channellock thread, a few of us have picked them up. Interesting to hear that they were a lucky find.
J
joedodge
Tampa, fl
Carlyle actually makes some nice tools. I have a Matco pair. I may stop and se if my Napa has those. I have some Carlyle stuff at work.
NoahG
Detroit, MI
Oh, sad to hear it was a small cache and not a special run. Now I’m even more glad I snagged two.
308guru
I'm curious; what is everyone's fascination with these particular pliers all about?
The 546/548 are slip joint pliers with jaws that are a little longer than the "traditional" slip joint. What do they do different/better or what specific use do they excel at?
J
joedodge
Tampa, fl
They grip well. They undo spring clamps well. With the narrower snout I can clean a mug welding nozzle out in a pinch. I can pull fuses from a packed fuse panel. Stuff like that. As a diesel mechanic welder they just come in a lot more handy
signcrafter
Doesn't look like any stores around have any in stock but des moines warehouse does so can have shipped to whatever napa you want and pick up tomorrow. Or if you work close by just stop at the warehouse and get them. It's right behind habitat for humanity off 235 and Euclid.
chohdog
Southern California
Reviving this old thread for a little more info. I too became a fan but couldn't find those 548's, so decided to buy the rebranded Matco pair as I found them for a great deal on Ebay. A few days later, found out that Carlyle had some NOS inventory at an even greater discount. So I did what every GJ member would have done, and bought those too! They are very close, but obviously the Matco/Channellock have the upper hand for final workmanship and details, steel thickness and overall feel. Both likely like the get the job done in the same manner, but thought you'd all like to see the comparison.1000008737.jpg1000008738.jpg1000008735.jpg1000008736.jpg
CHI_Tool&Die
Chicago, IL
You got a nice older pair of Matco pliers. The ones I see on the truck are laser etched and have a double dipped handle. I need to talk with my rep but Matco just rolled out a three position plier set so these may be headed to the graveyard.
nicks78camaro
Pittsburgh, PA
Got a set of these Matco pliers a few years ago on ebay brand new. Used a few times. Pretty nice.
Could let go of the set if someone wants.
ecotec
Was this pattern of pliers called cycle pliers or bicycle pliers at some point?
NoahG
Detroit, MI
I’ve seen Knipex use that term.
I see them as a descendant of gas/gas fitters pliers. I hated them until I discovered American made 8” and 10” versions. All I ever knew growing up were cheap imported 6” variants.
Early in my career I had a boss who grew up a Wisconsin farm boy and did EVERYTHING with a pair of “common pliers” (as he called them) and a circ saw. Ever seen a man freehand a circle cut and then plane a board with a circ saw? I have.
Dave455
Sussex, England
Cycle pliers look similar, from some pictures, but they generally have much thinner jaws.
This side view of a pair of Knipex angled bicycle pliers shows the thin jaws. Some are even thinner.
The 548’s are basically narrow jaw slip joint pliers. They’re good tools. If you’re going to use slip joint pliers they generally work much better than the wider jaw models. I don’t know why Channellock discontinued them.
Dave455
Sussex, England
I live in Sussex, England.
I’ve seen screws put in with a spade…..!
