2026 Garage Sale Thread (15th Annual)
zachgeo
Just some small items from an estate sale yesterday. They actually had some nice vintage tools, but nothing I particularly needed or was looking for. Might go back today to look through the vinyl LPs. The faux pearl handle knife is an Imperial that was cleaned up and sharpened a bit prior to the photo (it was coated all around and inside in grease and oil) The other knife is a CamCO electrician's knife which will probably need more work than the Imperial. I dont know why I'm obsessed with these old style oilcans, but whenever I see one in a size I don't have I pick it up! The soldering iron stand with cage gizmo is unused. Definitely an improvement over the rinky-dink tin stand that came with my Radio Shack soldering iron that I bought in the '90s...
Today’s mixed finds from the two Sunday flea markets.
-Blue-Point adjustable
-Matco 1-1/16 combo
-Napa long 1/2” ratchet
-Craftsman 3/8 polished ratchet
-Proto 4061 puller
-Westcott 6” curved adjustable
-Cochran 24” pipe wrench (pat’d 1908)
-Dewalt misc. new and used bits
-Craftsman professional screwdrivers
B5786DCA-DEA2-4AEA-81BA-0F18295933C1.jpeg95E4C007-27EA-4012-98A5-7E20EF20F854.jpegE1C33C33-27B5-4B42-8019-89B405BF4355.jpegE5E1B0BE-330A-4ED4-A17A-B3498DDF76D8.jpeg
More small finds:
-P&C black adjustable
-Heyco BMW pliers
-Craftsman punch
-small Vise-Grip
-Snap-On 3/8 extension
-Easco 1/4” spinner w/female end
-Powr-Kraft 1/4” spinner w/female end
-Companion 1/4 ratchet
-Craftsman socket for rat. wrench
-Matco trim clip tool
-Kal USA 1/2” ratchet
ctuai
Des Moines, IA
Estate sale ($25): Northstar pressure washer (3 gpm, 2000 psi).
No gas in it when I bought it so took a chance and got lucky as it fires up and pump works great. Got a jug of house wash and a gas can thrown in. Been avoiding the hassle of small gas engines, but pressure washers seem to be one of the few places where they're still king.​
Beerhippie
Far NE Oregon
$25? Working Honda engine?
You ****!
Cart was designed by the same folks who designed our Champion PW cart--folks who have never used a tool on wheels. I hate that cart but still haven't gotten around to modifying it. Wheels go in the back, damnit!
ctuai
Des Moines, IA
Came across this today, from an old auto shop mostly Ford Model A era parts and stuff. What would this have been used for? Full bottle and it does weigh a pound.1000041129.jpg
I once bought a flask with about 7 lbs of mercury at a garage sale and figured it would be interesting to put it into a large petri dish and spin it into a parabolic mirror with a magnetic stirrer. I mean what else do you do with that much mercury.
It's actually not as toxic as people make it out to be, as long as you don't heat it up and inhale it. On the other hand, if it escapes it's container, it's almost impossible to clean up as it breaks into a zillion little non-absorbent blobs, which is obviously no good for you or the environment. Very difficult to sell or at least I couldn't figure it out. Goof around with it and take it to your local hazardous waste disposal depot... or give it to a buddy whose curious enough to take it :)
3jakes
South Central PA
Got any friends that are tearing apart computers & other electronics,
and have no need to fear neurotoxins?
How Mercury Gold Recovery Works (The Mechanics)
In artisanal and historical mining, mercury is utilized because of its unique ability to alloy with other metals: [1, 2]
    • Amalgamation: Liquid mercury is mixed directly into heavy mineral concentrates or crushed ore. The mercury chemically bonds with the gold particles, creating a silvery, solid or semi-solid alloy called an amalgam. [1, 2, 3, 4]
    • Separation: Miners typically squeeze the wet amalgam through a porous fabric like a chamois cloth or canvas. This presses out the excess liquid mercury for reuse, leaving behind a hard amalgam button. [1, 2]
    • Burning (The Hazard): To isolate the pure gold, the amalgam button must be heated. Because mercury has a relatively low boiling point (356.6°C), it vaporizes into the air, leaving behind raw gold. [1, 2, 3, 4]
Severe Dangers of the Mercury Method
    • Lethal Vapor: Burning mercury releases invisible, odorless, and highly toxic mercury gas. Inhaling these fumes causes permanent neurological damage, brain damage, kidney failure, and death. [1, 2]
    • Bioaccumulation: Vaporized mercury settles into the surrounding soil and water supply, converting into methylmercury. It permanently poisons local ecosystems, fish, and subsequent generations of people living nearby. [1, 2]
    • Chemical Hazards: Attempting to dissolve the mercury using nitric acid instead of burning it is equally hazardous. It creates highly toxic mercuric nitrate liquids and dangerous explosive byproducts (mercury fulminate). [1]
Yes. When the container was dropped in 7th grade science class, the stuff ran every whichway all over the floor.
We had fun "sweeping" it back into one place on our hands and knees, using sheets of notebook paper as "brooms".
We finally got it corralled, scooped it up with sheets of paper, and got most all of it back into the jar the teacher had opened to show us the stuff.
Fun times! (y)
Shiftless
East Bay SFO
Around that same era, I was in a science class where the teacher poured out a little puddle of mercury into a student’s hand so they could feel how heavy it was and how you could roll it around and pass it from one hand to the other without any “wetting”. Each student in turn took it into their hands to play with.
Yes... Fun times indeed.
(The neurotoxin angle, although delayed over 60 years, possibly explains my obsession with collecting old bench vises) 😎
Had a similar - non science class thing happen in grade school only the mercury was brought by one of the girls in class and passed around without the teacher being told...
Beerhippie
Far NE Oregon
"Flask" is the standard unit of measurement for mercury in commerce. It's defined as 76 lb and is about a quart at room temp.
Spilled mercury is "mopped up" with copper wool, as it forms an amalgam with the copper.
And yes, we did play with mercury in school. Cool stuff. We also inhaled lead all day, every day, and sprayed our produce with potent neurotoxins considered too horrible for use on the battlefield.
What were you saying?
Beerhippie
Far NE Oregon
More fun mercury facts: Old lighthouses, with their immense Fresnel lenses, used a mercury bath to float the lens assemblies. These were essentially frictionless bearings. Mercury is constantly outgassing at room temps.
Recent tests have revealed mercury in all parts of the lighthouses--including the living quarters.
Good thing no one has ever heard of a lunatic lighthouse keeper!
There were (are?) also telescopes that used a round, rotating tank full of mercury as a reflector lens. The rotation pulled the mercury into a flawless parabolic lens. Of course, you could only look at objects directly above the telescope--and briefly.
Crazy astronomers? Ever meet one?
benthetipsybear
I believe I read somewhere plagiarism is the sincerest form of flattery...or something like that. LOL Thanks for taking on this monumental task. Counting out "You *****" while commanding a ship of fools with tools is an endeavor.
Full quote: "Imitation is the sincerest form of flattery that mediocrity can pay to greatness." - Oscar Wilde
knock knock
Gave $10 for the wrenches and snap ring pliers on Sunday. Gave a dollar for the other today at a thrift store. Thought the snap ring pliers were snap on.
ctuai
Des Moines, IA
"Crazy astronomers? Ever meet one?" Lunatics? or Lost in the stars?
Beerhippie
Far NE Oregon
Close-out sale of a local landscaping business:
Pickaxe--I needed one earlier this season and didn't have one. It'll clean up nicely. Erie Tool Works 24" Pipemaster. Needs cleaning. Two partial rolls of twisted-pair wire, 14 AWG. Probably for underground sprinkler systems. I'll use them for automotive.
A definite TOO--I thought they had the final sale this spring. $15.
I left behind the extra parts bag--full, with instructions--for a vintage version of one of these:
MaxAxe multi-tool. I t was missing the axe, which is the base for the rest of it. I figured I didn't want to spend for a replacement axe--and I was right. ~$140 for the axe alone. If anyone has the axe and needs the rest of it, let me know soon. I can grab it cheap.
bmwrd0
Beaver Fever Oregon
Not much has been going on here the last week or so, a lot of sales that look good online, only to disappoint in person. But I did find a few things:
Weaver V9, random gear spacer, small vise, casino playing cards, Goodell Pratt driver, small unmarked wrench, random bracket, grounding clips, carriage bolts, security bits, Stanley driver, Blackhawk and P&C deep sockets, well used Proto brass hammer, body hammer.
I also picked up a bunch of books:
mostly SF paperback classics which you can read the titles of, but the green book is an early Graham Green first of England Made Me (1935) and the copy of Cooking Out of this World is apparently quite valuable, going by sold eBay prices.
INSP380
Cleveland, Ohio
Love that Brass Proto!!
Steve 👍
