Anyone collect vintage Taps and dies?
SquirrelsTools
Flint Michigan
A gunsmith would use those smaller size screws and threads. So would a lot of other trades--typewriter and sewing machine repair, etc.
I've actually been looking into it, hadn't really done any research on it. Gunsmith seems like the answer from what I'm seeing. It seems that 4-48 and one of the others are almost exclusively armory sizes/very specific plane set screw sizes for that time period. Wild, but explains why it's in such good shape for the age of it. The box is also mahogany veneered so*fancy* and all..
SquirrelsTools
Flint Michigan
17600283864237765878236229751703-jpg.2416418
SquirrelsTools
Flint Michigan
This though, is one of my most prizes possessions. Russell reversible screw plate set B5. Not to be confused with wiley and Russell. Massive 24 inch die stock handle, all USS sizes. Most of the original taps, three replaced with period Card taps.
I say prized possession not because it's especially valuable, it's probably worth a few hundred bucks. But because it was rusted so hard that you couldn't open the box. It was just a heavy box I paid $10 for. The amount of painstaking care and time I took to get it back to beautiful is a memory I cherish. I obsessed over it for a week, soaked the box open, pulled apart each die (two took gentle heating) and picked out every engraved letter one by one. Hell, I even managed to save some label surprisingly. I'm not sentimental about many things in the shop, but this... Yep.
tworley
Colorado
I've had these for probably 15 years now. I found them in my grandmas basement when we were cleaning out her house after she died. She had a husband who died in the early 80s. Only recently did I actually pull them out and clean them to see what they were. Its a mixture of Brubaker & Bros, Greenfield, Threadwell and Ace.
20250831_104800.jpg20250831_104745.jpg20250831_103256.jpg20250831_102551.jpg20250831_102540.jpg
After a search, I was happy to see that Lugz had done all the necessary research on these thread files. I found this Jaw brand one in the sleeve at yesterday’s estate sale. I was hoping that it was the earlier Reiff & Nestor brand.
I found another Jaw made Nu-thred thread file on Thursday at an estate sale. I hadn’t run across one since 2023. IMG_5311.jpegIMG_5313.jpeg
Lesserstore
Texas
I bought this used bottoming 10-32 pulley tap for a project, and didn't even realize that it was vintage. I looked up the brand: Winter, and that lead to a thread on Practical Machinist, which then lead to a (dead) link to a family website, but fortunately was saved on the wayback machine. Anyway, the company went out business in 1948.
Link to history:
I was unable to leave this Greenfield set behind when I spotted it at a sale last month. IMG_2753.jpegIMG_2752.jpeg
Wow, is that lots of different size and pitch taps, or just lots of duplicates? If the former, I bet lots of abandoned sizes in there, just the thing for old tool repair.
After several months I finally got around to going through the GTD set anc putting it in order. In answer to the question from RTM, there are multiples of most taps. All of the taps are NC, which seems odd. Maybe they offered a similar set containing just fine taps. The drill bits are number rather than fractional and many of them are original GTD marked. I found a GTD tap holder in my Gerstner box to replace the unmarked one the set came with.
jmwood
jmwood
I just picked this set up today American Tap and Die Company Greenfield Massachusetts
jmwood
Machine Screw Taps Greenfield Tap & Die
454ragtop
Carver, MA
Picked up this large tap handle this weekend, 36" long. That's an 1-1/2" - 12 tap for reference. Says AM. T & D on it, American Tap & Die?
Eric Brown
Just got his nice little set. Greenfield Little Giant set AA4. It is complete and all the cutting edges are in good shape, not a chipped tooth.
I got it primarily for the adjustable dies in the smaller sizes. I work on a lot of old tools and sometimes I would like to be able to over-size or under-size.
ararat
Ararat NC
Great condition for sure.
Yankee Wrencher
Aquidneck Island, Rhode Island
This screw plate set belonged to my late father-in-law.
I understand this is a Greenfield Tap and Die Corporation “Little Giant” Screw Plate set.
I’m told Greenfield Tap & Die was a major, respected American manufacturer based in Greenfield, Massachusetts.
humber2
Downunder
#5 is a popular set, obviously the last user of the set didn’t return the gear for the thread he worked but those items should turn up at garage sales or swap meets.
You’ll have to ascertain the thread form from the split dies remaining. NC or NF probably.
Here is the pricing structure from 1935
Yankee Wrencher
Cool stuff. Thanks.
mituzuna
Are vintage Ace and Blue Point tap and die sets considered to be on par with modern HSS tap and dies in terms of quality and cutting performance?
rustyzman
Chicagoland
Most of the Ace / Hanson and regular Blue Point or other house branded sets in the thin flexible plastic boxes with the removeable tray layer, that I have seen were carbon steel taps and dies. Not bad stuff, but not HSS. The carbon steel stuff works fine for repair work and light occasional use, but it will wear out quickly in comparison to HSS.
I would not shy away from them if they are available at a good price, they are still nice sets. Use a good quality cutting oil every time you use them.
RoninB4
Under My House
-In a word NO. Any cutter, tap, or twist drill made from HSS will almost always have it stamped/printed on the item. If it doesn't then it's plain (low) carbon steel and is an inferior material. Do plain carbon steel taps work for cleaning crud out of existing threads? Yes. But for cutting new threads in most materials they wear out faster and maybe won't cut at all if the material is above a certain hardness level. When a tap gets dull it runs a very real risk of snapping off when it's in the hole, you now have a much larger problem with removing the broken bits. Even HSS taps get dull and then run the risk of breaking but they easily outlast plain carbon. As an analogy would you rather buy 4 of the $3 hacksaw blades and need to use all of them or just get the $12 blade that will probably outlast the cheap ones? Your call.
-Yes HSS is more expensive, that's the price of admission. Some people won't think twice about getting some pricey new cordless gadget platform, a shiny "collectable" tool, or high priced garage decoration but go cheap on taps and twist drills. A foolish set of priorities but that's JMO.
