Imperial Journey - a Restoration Saga
Ohmthis
Outside of Louisville KY
Freaking slide rules and compasses to the rescue!!!! When you said drafting set, I said the **** is getting real! My dad has a ton of drafting tools that I have used and keep in my tool box. That was a great idea to make a series of radii to match what was there. I may make a set on poster board and keep with my fab tools!
R
rdoty
Massachusetts
I still have my first slide rule <digs it out of drawer> - a Pickett N4-ES Vector-type Log Log Dual Base Speed Rule... Slide rules make nice decoration, but I don't miss using them at all!
I find it fascinating how much modern solid modeling CAD systems are built on drafting style geometric construction. Almost everything I do while building complex solid models is based on drafting techniques I learned <way to many> years ago! Plus drafting based design really forces you to get good at visualizing parts.
While CAD is great you need physical tools to measure physical parts. And there is still a place for manual layout and classic Cardboard Aided Design!
dscheidt
There are adjustable radius gauges, which you adjust to match the radius you're copying, and and then read the result off the scale. They're not cheap, and you need an inside and outside, but they're very handy.
Ohmthis
Yep, my late stepdad (a tool and die maker) had radius gauges. A few minutes and some card board and I could make several. It’s an idea I guess. Thank you for the info.
R
rdoty
Massachusetts
Interesting! I wasn't familiar with them and had to look it up. Fascinating, elegant, and somewhat complex gadgets. The people who made the industrial revolution weren't dummies! I've got a huge amount to learn about machining, fabrication, and metrology. Thanks for the reference!
dscheidt
This is the sort I've used. (I don't know if they were this exactly, but they were similar). different from the fixed sort of radius gauges that machinists use. 1783565415964.png
No kidding. The number of amazing machines and mechanisms that came out of the 18th and 19th centuries are mind boggling, as are the ways they figured out how to make stuff with pretty basic machine tooling.
R
rdoty
Massachusetts
Unfortunately we aren’t done yet. Three back panels are required – two sides and a center piece. These panels fit around the mounting brackets for the seat back and arm rest. Unlike the factory cover, these will be seat material instead of carpet. Measure each panel, cut it out, sew it together, test fit, and then sew to the rest of the seat cover.
Finally we are ready to fit the entire cover. With some pushing, pulling, tweaking, and cursing the complete cover is in place and looking good. Flip the seat over the use hog rings to secure the seat cover to the frame. Then flip it back upright and check the overall fit. Not bad, not bad at all! Since everything is in its final position, cut out the holes for all of the mounting points.
Being thoroughly paranoid at this point, completely assemble the entire seat – including arm rest and seat backs – and check the whole seat over for any last problems. Everything still looks good…
Time to take the seat back apart, drag the engine hoist out of the corner, hook everything up, and call She Who Must Be Obeyed for help.
The seat base went back into the car smoothly. The mounting bolts slipped into their holes in the bottom of the car – everything still fits. Run the nuts onto the mounting bolts and tighten everything up. The next moment of truth – plug in the power seat and see if it works. It does! It moves in all six directions. So far, so good…
Install the arm rest with its cover. Install both seat backs. Install the trim pieces on the sides of the seats. Everything is still looking good.
Now for the real moment of truth – run the seat back to its correct position, slide in, and sit on it.
Wait for it, wait for it…
It is good! The seat is now firm and comfortable. Much better support and it doesn’t feel squishy. It even looks good! And there was much rejoicing!
New front seat
We’re not quiet finished – the front door cards still need to be done and I need to do some tweaking around the windows. But the car is usable and even looks good. We may eventually get a Thursday that isn’t raining so I can take it to a local car show!
R
rdoty
Massachusetts
In yet another demonstration of a lack of common sense I decided it was time to tackle the front door cards.
Unlike the replacement hardboard panels on the rear doors, the front doors still had the factory door cards. These were made from a cardboard like compressed paper material. Which was fragile when new. It doesn’t age well. If exposed to water it basically falls apart. I’ve been afraid to touch it…
But the job has to be done. Sometime. Sigh, it looks like sometime is now….
Pop the first door card off and plop it on the workbench. Carefully take the arm rest off. The Imperial has a trim piece directly above the arm rest – an aluminum sheet with a sort of floral pattern and a chrome plated metal surround. This was also carefully removed. The repeated use of "carefully" should convey my belief that this whole armrest was just looking for an excuse to collapse into a dozen pieces.
Original front door card
The first view of what we have to work with is a bit of a mixed bag:
Front Door Card, arm rest and trim panel removed.
The first thing you can see is the (f)ugly carpet along the bottom of the door. This absolutely has to go. What was Chrysler thinking??? (Yes, I'm actually aware of why Chrysler did this. I still think it is incredibly ugly!)
The second is that the door card is molded – you can see how the trim panel is partially recessed. This means that you will have trouble fitting things back together if you replace the factory panel with a flat piece of hardboard. This explains some of the challenges I had with the rear door cards. OK, I really need to save the factory pieces.
Time to carefully peal the old vinyl and carpet off. A heat gun softens the old adhesive and minimizes damage.
Front Door Card stripped
I’ve seen worse… It is actually in reasonably good shape except for the holes around the edges for the mounting clips. If I’m careful installing it should be OK.
R
rdoty
Massachusetts
The initial steps are like the rear door cards: cut and fit 1/4″ SewFoam to go over the whole panel. Double stitch the foam to the vinyl in 6″ squares – making sure that they line up with the stitching on the back doors. Spray the door card and cover with spray adhesive, fit the cover to the door, and staple on the back. The fit around the molded indents wasn’t great – but the arm rest and trim panel would pull everything into place.
The first major difference is the aluminum trim panel. These were worn and dirty. And ugly from the factory. Again, what was Chrysler thinking? I considered covering them with a nice walnut veneer. This would look rich – it was what Chrysler should have done in the first place.
I ultimately decided to just use some of the darker vinyl – I was already using it other places for accent. A round of spray adhesive, some fitting and trimming, and the updated trim panels were ready to go.
On the rear door cards the mounting of the arm rest and trim panels was a mystery. On the front doors taking them apart showed all of the mounting hardware and tricks.
First was to position the aluminum trim panel and the chrome trim. The chrome trim had a series of “nails” sticking out the back when went through holes in the door card and were then bent over. The arm rest used a combination of nuts and bolts, sheet metal screws, and the “nails”.
There was a bit of fiddling to deal with the thicker foam backed vinyl, but everything eventually went together. The last step on the workbench was to carefully install the retaining clips around the edge.
Time to cross my fingers, cart the refurbished door card over to the car, and attempt to install it. After a few gyrations the door card clipped into place. Install the courtesy light into the door and verify that it works. So far, so good. The last step was to install the power window switch and see if the window still goes up and down.
The window goes up. The window goes back down. The window goes up again. The door closes. The door opens. The door closes again. And there was much rejoicing!
Spend a few minutes admiring my work. Then on to the remaining door.
Front Door Card finished
I’m rather happy with how this turned out! The old fiberboard held up better than I expected. The trim panel above the arm rest adds a nice bit of contrast. Walnut would have been nicer, but this is fine. This task went better than I expected going into it – always good when that happens! I’m beginning to look forward to cruise nights this summer.
R
rdoty
Massachusetts
As I've mentioned once or twice, I seem to be a glutton for punishment. With the front doors done the difference between the front and rear doors was obvious.
I actually had all of the trim pieces for the rear doors. They were in the trunk of the car when I bought it. After doing the front doors I knew how all of these pieces fit. And how to do a better job of fitting the arm rest.
Sigh. Fine. Pull the rear door cards off the doors. Dig out the aluminum trim panels and chrome trim. Start the process from the middle.
First, cover the aluminum trim panel with vinyl and then fit it and secure it in place.
Fit the arm rest and start adding bolts and sheet metal screws to hold it in place. The bottom of the arm rest was warped, especially on the driver's side. Screwing it to the door card flattened it out nicely.
RearDoorCardWithInsert.jpgRear door card with insert added. Arm rest is now secured to door card.
Install the updated door cards back on the car, test everything, and rejoice.
Matching front and rear doors
Of course it wasn't quite as simple as this description might imply... But it did go fairly smoothly and the results were good.
R
rdoty
Massachusetts
A set of fabric covered U-shaped trim pieces hold trim panels to the center pillars of the car. These are in absolutely horrible shape. I’ve been looking for replacements for the last four years with no success. And I’ve been afraid to touch these lest I totally destroy them, leaving me up the excrement waterway without a manual propulsion device.
After finishing the rest of the interior these pieces were really bugging me. With considerable and painful cogitation I dreamed up an almost plausible way to cover them with vinyl.
Original U-channel holding trim panel in place
Yeah, that’s ugly…
Applying a liberal dose of fast setting epoxy to secure my courage in place, I removed the first piece of U-channel and tossed it onto the workbench.
Measurements and careful calculation suggested that a strip of vinyl 2-1/8″ wide would cover them.
Point of no return – carefully cut the cloth covering off of the wire spine. I’m officially committed!
My biggest concern was how to hold the wire spine and vinyl in place while wrapping the vinyl around the U. And how to secure the vinyl cover to the wire spine. The answer, which gave me the impetus to finally start this job, was three steps.
First, make a fixture to hold the vinyl and wire spine. This was done with two pieces of plywood spaced just the right distance apart making a channel for the vinyl and wire spine:
Fixture to support vinyl and wire spine
This holds the vinyl in place, but how to keep the wire spine from moving when I fold the vinyl over the edges? This is the step that kept me from touching these pieces for several years. I have a clear nightmare vision of trying to keep the vinyl centered while wrapping it over both legs of the U as being a a four or five handed wrestling match with a dyspeptic python. While everything is liberally coated with glue.
Thus the second step – run a bead of urethane adhesive down the bottom of the vinyl and bed the wire spine into it. This locks the vinyl and wire spine together.
This made it “easy” to wrap the vinyl into the center of the U – but how to hold it in place once wrapped? The solution was a liberal application of contact adhesive to the vinyl backing and to the wire spine. This is rather weak – the wire spine doesn’t have much surface area to bond to. But it doesn’t have to be strong – it just needs to hold the vinyl in place long enough to install the trim piece. The spring action of the wire spine locks everything into place after installation.
Between the plywood fixture and the urethane locking the spine to the vinyl it was surprisingly easy to smoothly wrap the vinyl into the center of the U. Coat the vinyl backing and the wire spine on one side with contact cement and give it 10 minutes to set up. Start at one end and carefully roll the vinyl over the edge. Every few inches stop and press the vinyl firmly against the wire spine with a plastic body and trim tool. Continue until one side was done, then flip the fixture around and repeat on the other side.
Refurbished U-channel installed
I’m rather pleased with the results. The final outcome is exactly what I was hoping for but didn’t really quite expect when I started this task And there was much rejoicing!
Fixr
SW VA
Yeah, that’s ugly…
12 extra points for the use of "dyspeptic".
R
rdoty
Massachusetts
With the existing trim around the column between and back doors upgraded and looking good my attention turned to the rear trim pieces. Despite years of searching, I haven’t been able to find any more of the U-shaped spring trim. OK, if I can’t find an exact replacement, could I make something that would work?
Every problem now looks like something that can be solved with a 3D printer. I can’t come up with a way to make the entire clip as a single piece – but what about making a series of 1/2″ or 1″ clips and stringing them together? It! Could! Work!
Fire up Fusion, sketch out a 1/2″x1/2″ U-shaped clip, extend it to 1″ long, knock it out on the 3D printer, and optimistically head to the Imperial.
Where it didn’t come anywhere close to fitting. Not to mention that there is a piece of door weatherstripping right where the clip would go.
OK, time to study this edge of the door opening more closely. Nope, nothing like the edges of the center column. Completely different shape.
Study the situation more closely. There is an L-shaped turned in edge on the door frame with the filler piece fitting inside the L. Dredging up the distant memories of long lost design skills, maybe a piece that locks into place at three points on the profile of the door frame could work? This would cover the top of the frame and extend down onto the filler. With the right design the printed plastic should have enough flexibility to snap into place and enough rigidity to lock into position.
Cross section of rear door with concept for trim retainer
Take a set of measurements across the door frame and filler piece, head back to Fusion, and start to design. The design went surprisingly quickly – leading me to suspect that it wouldn’t work… It is a small part, so it prints out quickly.
Head over to the car and try to snap it in place. It almost works. Which is actually quite encouraging! OK, the top needs to be a bit wider and the throat needs to be a bit deeper.
Fusion is a parametric design system. This means that you can change a design simply by changing dimensions. I was able to modify the design of the clip simply by changing two or three dimensions. And by changing I mean simply selecting a dimension and typing in new numbers – it was literally a 20 second job to change the dimensions and send a new part to the printer. And the new part printed in 7 or 8 minutes.
The new clip was closer but could still be improved. Version 7 of the design was finally the one I wanted. This wasn’t a problem – it was a very common example of the iterative nature of engineering design. The beauty of modern technology is that I was able to go through these 7 iterations an about an hour and a half with little effort!
To be continued...
R
rdoty
Massachusetts
With a profile that worked the next step was to extend this profile along the door frame – which had a variety of curves. The solution was to create a set of clips in 1/2″, 1″, and 2″ lengths. I then created multiple copies in the printer software and printed out 24 clips as a single job. This took about three hours, so I let it run and came back the next day.
Starting at the top I snapped the clips into place on the door frame, using 2″ clips for the straight sections, 1″ clips for the slightly curved sections, and 1/2″ clips for the most tightly curved sections.
Once again it almost worked. Most of the clips fit fine, but there was one place where they just wouldn’t lock into place. Oh! There is a doubled thickness of sheet metal where two panels meet! Look at what needs to be changed, head back to Fusion, and print off a modified clip. This time it only took me three iterations to get something that worked.
Finally! A set of clips covering the entire edge of the door frame.
The next question is how to wrap them with vinyl? They have to be removed from the door to do this, and 22 loose clips will be a pain to wrestle with. Fortunately I could kill two birds with one stone. I was concerned about the clips printing through the vinyl, and had planned to cover them with 1/4″ foam. By gluing the foam to the clips while they were still on the car they would stay in position while wrapping them with vinyl.
Worked like a charm. Glue the foam to the clips, carefully pop the clips off of the door frame, take everything over to the bench, finish gluing, and wrap it with vinyl.
Before anyone asks, the white clips and their location is based on a fairly esoteric engineered materials structural properties requirement. I ran out of black filament.
Take it back to the car and carefully snap each clip in place. And Viola! – good looking trim around the back seat!
This is a major change from when I first got the car. The interior has gone from horrible to something I’m reasonably proud of.
R
rdoty
Massachusetts
It’s with great relief that the interior is finally done! No more seats, door cards, trim, door switches, lights, or other tasks!
Yeah, about that…
I’ve seen some designs for custom trunks that I rather like. Basically the same kind of panels as the door cards – covered with vinyl, padded, and pattern stitched. I ordered so much material for the interior that I still have a fair amount left. Even after all of the mistakes and re-work. We all see where this is going…
Empty everything out of the trunk, including the carpet I put in a couple of years ago. Hmm, the surface rust is still there. Bummer.
You know the drill from the rest of the car: heat and scrape all of the undercoating off. Wire brush and sand the rust. Clean the entire surface followed by two coats of epoxy primer, sound deadening, and carpet.
Well, this time I got lazy. I just couldn’t work up any enthusiasm for doing all of this in the trunk. Yes, still had to wire brush the surface rust. I had several cans of rubberized undercoat left over, so hit the entire trunk with undercoat. That stuff is durable and sticks well.
The trunk is the last major surface without sound deadening. Order another box of sound deadening material and apply it to the entire trunk including the rear wheel arches. I took the car out for a drive half way through this job and it was already noticeably quieter.
At this point I hadn’t decided whether to go completely around the trunk with covered panels or just panel the sides and cover everything else with carpet.
In either case the starting point is panels that go against the side of the trunk from the wheel wells to the rear of the car. Start by making paper templates for the curved areas – mainly the corners. Once these fit, piece them together, trace them onto a scrap piece of plywood, and shove them into place.
Nope, didn’t fit. Go through several cycles of trimming and test fitting the panel until it fits properly. Quite a bit of fiddling was needed on the driver’s side – the jack sits in two brackets right next to the sidewall of the trunk and extends into the wheel well area. Several cutouts were needed to allow the jack to be stored in the factory location.
Once the template fit properly – on both sides, I’ve learned to be paranoid! – drag out a left over sheet of 3/16″ plywood, trace the template, and cut it out.
From there on it was basically the same as the door panels: mark and cut a piece of vinyl 1″ larger than the panel. Mark and cut a piece of 1/4″ sew foam the size of the panel. Use spray adhesive to bond the vinyl and sew foam together. Decide where to start the decorative grid both horizontally and vertically. Lay out the entire grid with erasable ink using the same 6″ grid that was used on the door panels. Sew the vinyl and sew foam together along the grid. Twice.
Panel cover with grid for stitching
Lay the sewn piece down on the workbench. Lay the panel board on top of it. Wrap the vinyl around the edge of the vinyl and staple it in place. Go around the entire panel, pulling and stretching the cover so that it is tight with no wrinkles. Flip the panel over and admire my handiwork.
Slip the panel into place in the trunk. Hey – it actually fits! As mentioned, I’m paranoid – so the driver’s side was done first. Dig out the jack and slip it into its brackets. Surprise! The jack actually fits! And there was much rejoicing.
Test fit of panel with jack
Lather, rinse, and repeat for the other side of the trunk making a mirror image of the first panel. Of course without the cutouts for the jack. This one also fit.
The last step was to apply velcro tape to the back of the panels and the side of the trunk to hold them in place.
With the panels done, pull them out, store them carefully, and start working on the carpet.
R
rdoty
Massachusetts
Soon as I got to that line my mind said "Oh boy... I'll bet it's one of those big-*** bumper jacks!"
Your last photo confirmed it.
Please never get under that vehicle if it's supported on that jack.
Get under a car supported by a bumper jack? Oh HELL NO! I don't even like to touch a tire when using a bumper jack!
I'm the type of person that uses 6 jack stands when working under the car - one for each corner and a couple under the frame just in case. As long as I have them, might as well use them.
The bumper jack is largely decorative - it came with the car, so might as well display it in the trunk. I'm looking for an original tire iron to go with it.
Thank you for your concern. I may have mentioned that I have a deep seated belief that the universe is out to get me and I see no reason to help it!
We sold those things. "Universal Tool & Stamping, Butler, Indiana" bumper jacks, scissor jacks, lug wrenches. Apparently they were an OEM supplier.
Used a lot of them (because that's all we had and we didn't know any better.)
Loved it when you'd get the rig up, tire off the ground, and the whole thing would go sideways - jack would collapse, brake drum come down on the pavement. Fun times!
Shouldn't be difficult to find a lug wrench. The OEM one would have just been kind of an L-shaped thing with a socket at one end a a "screwdriver tip" on the other end to pull the hubcap, right? I find those in second-hand shops all over.
Excellent idea undercoating, padding, and lining the trunk. Should make the passenger compartment quieter. Does that thing have "resonator mufflers" under the trunk like my old Pontiac?
R
rdoty
Massachusetts
Don't you just hate it when things go sideways?!? That is one of the situations where things can get real ugly, real fast. I'm trying to remember if it is "young and invincible" or "young and dumb"?
Yeah, they made hundreds of millions of those tire irons, so it shouldn't be that hard to find one.
It has resonator mufflers, but not under the trunk - see an earlier post in this thread where I describe my 4D wrestling match with the exhaust. I thought the resonators went under the trunk and just couldn't make things fit. Then I found a picture with resonators forward, big mufflers aft, and life became much better. The new exhaust is indeed "Imperial Quiet".
^ The scissor jacks we were selling were even worse - cheap things that would topple over sideways if they weren't set up properly under the vehicle.
Scariest were the cheapie "ramps" when they first came out - they were really thin steel and super cheap - $20 bucks a pair.
Guy came back with a set - flat as a pancake.
He'd driven his 1962 Buick Invicta up onto them and flattened them. We didn't carry that line very long.
I never trust jacks or ramps, and I'm nervous even with my new jack stands! :oops:
R
rdoty
Massachusetts
They have a word for people like us - survivors!
YEP.... and no matter how many times we try to warn people about this, we still see......
R
rdoty
Massachusetts
A few of years ago I picked up a couple of yards of cheap indoor/outdoor carpet and (somewhat roughly) cut and fitted it to the trunk. The plan was to replace it with something better when I actually finished the trunk.
But after (semi)careful consideration, it didn’t look too bad. It was already (somewhat roughly) cut and fitted. The new side panels hide the edges of the carpet. And there were things I still needed to learn about working with carpet.
OK, change of plan – finish off the existing carpet and then decide what to do.
Something needed to be done about the rough edges of the carpet. These edges are typically bound with bias tape – a fabric tape that wraps around the edge of the carpet and is sewn in place.
Carpet binding. Including sewing error at top…
There are sewing machines specifically designed to bind the edges of carpet. Just feed the carpet through the machine and you have a perfectly bound edge. Of course these machines cost several thousand dollars.
They make gadgets that fit regular sewing machines – including Juki – and fold the bias tape over the top and bottom of the carpet and hold it in place while sewing. There are commercial versions for several hundred dollars. There are also a bunch of different models in the $10-$20 price range. Several hundred dollars is too much. But I’m willing to risk $10 and some of my time on one of the cheap ones.
Tape folder – carpet binding tool for sewing machine
You may find this hard to believe, but the cheap tape folders ****. And I **** at using them. It is difficult to load the fabric tape into them, difficult to keep the tape properly feeding through them as you sew, and difficult to keep the tape on the carpet when sewing. I kept sewing off the edge of the carpet.
It could be that this binding attachment is intended for regular fabric – I had to open up the throat just to feed this thin indoor/outdoor carpet through it. There is no way that it could be used with regular carpet.
After a fair amount of practice I got somewhat less bad. But it was still a painful experience and there was usually at least one place on each edge where I sewed off of the carpet.
After finishing edging the entire carpet for the trunk I learned a distressing truth: After all that work, I don’t really like the way it looks. A big part of this is the tape I used. Part of it is probably the cheap, thin carpet. But I just don’t like it. OK, something to keep in mind for the future!
R
rdoty
Massachusetts
Two steps forward, one step back. I have faith you'll sort this, just as you have the interior!
I'll get it sorted, one way or another. Thanks for the vote of confidence!
More research turned up a better way of binding using regular sewing techniques. More work than just shoving carpet through a cheap POS tape folder, but produces better results. I will keep this approach in mind for any future carpet projects. Along with getting better tape!
As the saying goes: Live and learn. Or don't live long...
R
rdoty
Massachusetts
I'm very happy with the Instabind carpet binding. It hot glues on. I used some cheap Home Depot carpet but I love the look. https://www.hotrodders.com/threads/1947-studebaker-m5-truck-build.547538/page-4#replies
Interesting! Will keep Instabind in mind for future projects.
You, sir, have serious fabrication skills! Thanks for the link - that is a great job on the '47 Studebaker.
Of course the easy way out would be to take the carpet back to the store and have them bind it. But what is the fun in that!
v8nutz
rocklin,ca
Thanks a lot. I never thought I could do my carpet like that. I did find that the adhesive that is on the Instabind was too weak so I used some of the Landau contact cement to attach the binding and then the hot glue around the edges.
