Geotextile under slab?
maverick302
SE PA
Is there a benefit to using geotextile beneath where the slab goes? It would be placed beneath the stone like so:
Slab
2A modified stone, 6-10”
Geotextile fabric
Prepped dirt pad
Seems there are some conflicting opinions on this. I believe the purpose is so the dirt doesn’t migrate up and mix with the stone, essentially sinking the stone and losing your compacted base. I’ve read some people disagree that this mechanism is a valid concern and there’s a reason it isn’t common.
matt_i
SE Michigan
Can't believe it would ever hurt you. Over a long time the soil fines could start to migrate. Also the criticality of maintaining your slab height is important.
Some of it depends on what kind of point loads you are putting on it.
Thick concrete acts like a washer distributing the load over a larger area thus lessening the propensity to smash little rocks into the subgrade.
Bondo
Greenfield, Maine
Slab
Geotextile fabric
Prepped dirt pad
Ayuh,..... It depends on what the Prepped dirt pad is like,.....
If it's stable solid ground, probably a unnecessary expense,.....
If it's on a pool of clay or possibly wet area, yes, it'll help, alot,....
Dodgeboy2020
WI
I'm not an expert on soils as such but I know I have been around a fair amount of slabs being installed and never have I seen the geotextile fabric used. Now that being said when I had my house built I did have them put fabric under the stone that made up the base for my driveway. Reason for that was the property has been a farm field for over 100 years and there was known areas of unstable soil in the path of the driveway. The fabric has done it's job, there was almost zero movement of the compacted stone during the course of construction to the point that the mason even asked if I had installed the fabric as he had experienced concrete trucks getting stuck in similar situations in the past and was surprised at how well my driveway held up. As far as the slabs in my garages was concerned there was no fabric placed below the stone base and there has been zero movement or concerns and it has been almost 7 years now.
RivennHewn
PNW
Geo over 6-10” rock will create air pockets that lead to settling. A course of compacted 5/8 -minus over the rock, then the geo will provide a stable base
As Bondo stated, it all depends on the native, undisturbed base you’re working on.
KenC
oklahoma
I think you are misinterpreting his terms. I see 6-10" thick crushed stone. 2A modified in my area would be 2" crusher run, a really solid packing base material.
The lowest layer is the most critical IMO, the type of 'soil' and layering/packing that is done. If that part is done well I don't think the textile layer is needed. I would however place a vapor barrier as it seems like everywhere I want to build has water too close to the surface at some time during the seasons.
welder4956
Birmingham, AL USA
Slab
Geotextile fabric
Prepped dirt pad
This is exactly the configuration used on the slab in my garage. There was a concern on the compaction for a slab on grade, so it was excavated to about 3 ft. on one end and 1 ft. on the opposite end. Then block wall foundation, geotextile fabric, fill with 3/4" stone, vapor barrier, 6 x 6 mesh, 4" of concrete. Not a single crack in 9 years so far.
RivennHewn
PNW
I stand corrected.
I still like the 5/8 minus over the 2”, especially under a VB
TomBexley
USA
The common thread in the replies seems to be that the native soil matters more than whether fabric is automatically good or bad. If it were mine, I would want to see what happens while the first lift of stone is being compacted. Does the subgrade stay firm, or does the stone start pumping down into soft soil and bringing fines up? That seems like a much better clue than whether the last five garages somebody saw had fabric under them. Also ask the concrete guy what he thinks the actual subgrade is there. Six to ten inches of well-compacted stone over solid undisturbed ground is a different situation from filling over wet clay.
phred
NC
I don’t see to purpose unless you have poor soil. Even then it would do little good. Properly compacted soil, adequate stone base and a reinforced slab should not compact the sub grade. We’ve poured slabs over very loose souls with the correct reinforcing and none have moved in over 30 years with traffic loads on them.
C-S-H
The geotextile is used on the drainage plane between a fine soil subgrade and open graded sub-base/base. You are using 2A Modified which is a dense graded base course with fines. So the answer as to whether to use it or not is maybe. There could be a structural reason, or a drainage need to use it specified to you by your geotechnical engineer.
BombShelter
State of Hockey
I like CETCO Voltex, it's a high-mil vapor barrier with a coating of bentonite. If the vapor barrier gets punctured, the bentonite "waterproofing" stops water from moving through the concrete. For under-floors it's pretty easy to install, just roll and overlap, they come in 4' x 15' sections and are around 1/8" thick.
The white in the photo is part of the mat the bentonite is embedded, it has small fibers pointing up that grip into the concrete pour. Buildings like these will never leak water unless someone rips the membrane and it isn't repaired. Bentonite is all-natural and long-term testing shows it doesn't degrade when encapsulated in the ground.
