Thank you!Nice truck. Simple, nice color, great wheels. Wow. Couple of roof antenna's and I'd think you were a cop and that's not a bad thing. LOL
Zim
Took a good deal of effort to get it to where it is today.
Zim
Did you check the flywheel, and make sure the key is OK?Taking the rider apart again, backfire, stall under load. Electrical or fuel, that is the question. I was hoping to get done cutting grass for the season, but alas, we don't get those choices when using 25 year old mowers. First up to clean the carb.
That's called a pick and mattock. I have a few of varying sizes.I might even put an edge on the hoe end of the pick....
CRS strikes again.That's called a pick and mattock. I have a few of varying sizes.
I have a set of rebuilt E7TE heads that have been shaved 0.020" if you're interested. I need to get them out of the way.
Zim, you do realize those D8OE castings have a 68 or 69 cc combustion chamber. Its going to drop compression on that Foxbody from stock 9:1 to 8.3 - 8.4 ?I'd love to but I'm strapped after building this garage and I haven't even thought about my project (47 jeep or 65 thunderbird)
Thank you tho.
Zim
...they were from the UK....Forgot to mention, while I was out of the shop and terrorizing the local back country roads, I came up on a very slow driver on a straight stretch of road. I signaled my intention to pass with a flash of the headlights and a short toot of the horn. As I pulled to the left to pass, they pulled to the left. I pulled farther to the left, they pulled farther to the left. WTF? They continued to slow, and I finally realized they wanted me to pass on the right. Who are these people?
This was a two-lane gravel road with plenty of room for me to pass if they just stayed in their lane.
It will be worth it once you get it sorted out. Every Hot Rod is better with a clutch.In long running projects, I often set a goal item to be mental “last thing” that completes the project. Working on the TKX install, I picked the shift knob.
Installed today.
Everything is now “done”.
Jacked the car down off of the cribbing. Pushed it out to the driveway, and prepared to test it. They recommend first start with transmission in neutral, clutch and brake pedals depressed. Seemed reasonable to me. So, after rechecking everything, reconnecting the battery, turned the key and … got a nice “whir” from the starter. Nothing else spinning.
Pushed back in to the garage. I’m not used to “race car” starters. Pulled the starter off, found that the Bendix gear was hitting the flywheel, so not engaging the gear teeth. Reinstalled using the other set of mounting holes, moving the starter outboard a bit, hopefully enough to let it engage.
Pushed out again. Turn key, and we’ve got engine rotation. And eventually, vroom. Let the engine warm up.
Let out the clutch, nothing happened. That’s good and expected, trans is in neutral. Clutch in, shift to first, clutch out, and we’re moving forward. Tested reverse, moving backward. Went for a short test drive.
Problems:
1. No speedometer. I probably need to reconfigure the 90* adapter to spin the other direction. Should be no big deal.
2. It doesn’t feel like the clutch is fully releasing. Either I need to spend more time bleeding the system, or it needs another shim. A shim means pulling everything back apart. So I’ll try bleeding it first.
For future reference, next time you want to pass someone maybe try just using your turn signal? Flashing your lights and blowing your horn might seem aggressive to some and they might want to block you out of spite.Forgot to mention, while I was out of the shop and terrorizing the local back country roads, I came up on a very slow driver on a straight stretch of road. I signaled my intention to pass with a flash of the headlights and a short toot of the horn. As I pulled to the left to pass, they pulled to the left. I pulled farther to the left, they pulled farther to the left. WTF? They continued to slow, and I finally realized they wanted me to pass on the right. Who are these people?
What is a TOO yard sale?Hit a TOO yard
That occurred to me. The canyon I was driving seems to be about 90% tourons. It was also the most crowded backroad I've driven in a long while. I'm used to seeing no more rigs than I could count on one hand in a day's driving....they were from the UK....![]()
Bingo.TOO = Target Of Opportunity, or an unplanned stop, as I understand it.
It's pretty much SOP on backroads around here. Not lots of folks paying attention to what's behind them, and a sudden, unexpected pass can turn nasty.For future reference, next time you want to pass someone maybe try just using your turn signal? Flashing your lights and blowing your horn might seem aggressive to some and they might want to block you out of spite.
