Mini split AC union
jjrbus
Florida
I am in need of a 1/4 inch flare union to test my CPS vacuum gauge and hose but not sure if the unions sold at the big box stores are the same as refrigerant unions. Are they the same or different?? 1789175404615.png
Ohmthis
Outside of Louisville KY
I put the “vacuum” (I’m assuming micron gauge) on one valve of a recovery tank. I connect my hose from a vacuum pump to the other valve. Pull a vacuum, and watch the gauge. This set up tests the hoses, micron gauge, and pump.
J
jjrbus
Florida
Thanks it appears the 1/2" acme cap on my vacuum pump is not sealing.
Firebrick43
West central Indiana
Most residential units use 1/4 SAE flared fittings and some mini splits now use 5/16 SAE
Are you sure its acme? Most pumps are SAE flared, at least every single one I have used, mostly JB.
