Lowes deals/sales/clearance
Etchase
Hawaii
I have the Bosch and like it. The blades are very expensive. I don’t use mine much so it’s not a big issue. That’s a terrific price so you can buy 100 bucks worth of blades before you break even with the DeWalt. I’m sure the Dewalt is a good tool also. I’m glad they’re starting to include bags with their tools, so we don’t have to buy them.
mikeinri
Direct Comparison Overview
FeatureBosch GOP18V-34B12DeWalt XR 20V Max (DCS356)
Power & Motor18V Brushless20V Max Brushless
Speed Range10,000 – 20,000 OPM0 – 20,000 OPM
Power SwitchSlide Switch (Constant On)Variable Speed Trigger (with lock-on)
Blade InterfaceStarlock / StarlockPlus (Hands-Free Ejection)Universal / Open-Back Quick-Release Lever
Oscillation Angle3.4°1.6° (Standard XR) or 4.2° (Newest Gen)
Vibration ReductionUp to 80% reductionStandard isolated headbox
1. The Blade Changing Interface (The Biggest Differentiator)
Bosch (StarlockPlus): The GOP18V-34 uses the co-developed Bosch/Fein Starlock system. It features a cupped, 3D interface that snaps onto the blade hands-free, transferring maximum torque and minimizing energy loss. To change blades, you simply pull a mechanical lever, and the hot blade pops right off without you having to touch it. The Downside: You are forced to buy Starlock-compatible blades, which are significantly more expensive and harder to find from cheap third-party brands.
DeWalt (Universal/Open-Back): DeWalt utilizes a proprietary squeeze-lever quick-release. It is heavily praised by contractors because its open-pin system accepts almost any standard universal or open-back blade on the market, giving you access to affordable, readily available hardware store accessories
Which One Should You Buy?
Choose the Bosch GOP18V-34B12 if:
You value maximum comfort, want unmatched vibration dampening, prefer a slide switch over a trigger, and don't mind paying extra for premium Starlock blades. It is also the obvious choice if you are already invested in the Bosch 18V / AmpShare battery system
Choose DeWalt if: You want the freedom to buy cheap, generic blades from any brand, prefer the dynamic feathering control of a variable speed trigger, or already own a garage full of DeWalt 20V Max batteries.
Wow, that looks suspiciously like an AI summary...
Mike
wire
Mike
Yes that is an AI summary, it was really easy to get that info, I just typed into google "Bosch GOP18V-34B12 vs DeWalt XR 20V Max (DCS356)". It's so easy it makes you wonder why more people don't use it. :ROFLMAO:
I did take the time to verify what it was saying, should I have posted it with a disclaimer?
mikeinri
No disclaimer needed, but like you, I always verify. AI is wrong for me more often than it's right. But, I tend to use it to find old, obscure info.
I definitely recognize the style (and seriously dislike the flowery adjectives and phrasing AI adds when I'm looking for a "forensic" / factual comparison).
Mike
FullRaceMerc
SoCal (SGV)
I like my 20v dewalt, but have no experience with the bosch to compare. It replaced an old corded unit that took different blades. I do use the variable speed to get the cut started in the right place.
It came with a bolt on adaptor, which would hold my old blades. It was nice to be able to burn those up. Once those were gone I removed the adaptor & it's easier to cut flush without it. The regular blades swap with a squeeze of the lever.
Chuckster in NJ
Hunterdon County NJ
Pretty sure most posters here are aware of what chatgpt is and how to use it. Asking questions here is to try and get a real persons opinion of using things.
TRUE! But the answer may not be the answer you want to hear.
TIP! DO NOT let ChatGPT control your life or how you think…….. Seek out real humans.
wire
Interestingly enough only one person gave an opinion of how much they liked/didn't like the Bosch oscillating tool and that was 2 days ago. I wouldn't advise holding ones breath waiting on another. :ROFLMAO:
JerseyBoatBuilder
Florida
I have the Bosch 12 volt oscillalting tool and like it a lot.
FYI there is a bunch of starlock to universal adapters out there.
The 3 blades in that kit deal Are $41 at Lowes if I remember correctly
driftpin
I am doing a minor bathroom re-model, new undermount sink on a new cultured marble top, on a new vanity; and a new Kohler elongated toilet. Walls are porcelain tile, floors are porcelain tile, original to the house. Same for the bathtub. It was built in 1961, it'a a MCM 1-story ranch house.
The bathtub had a little mold on the wall/tub caulking when the prior tenants vacated. I tried to cut-loose the caulking w/a long-handled single-sided razor blade holder, and a folding utility knife w/a fresh blade, but they were fighting the remnants of a before-caulking grout attempt which I hadn't been able to fully-remove, so it got covered w/the caulking. The 'sandwich' layers were defeating me until I decided to go 'full-monte' with my oscillating tool.
I selected a toothed blade maybe 1-1/2"-2" and a Bosch adapter disc, and had at-it. Wow, the tool zipped-through the old grout under the caulking, and I quickly was able to remove long strings of that which had squeezed underneath the bottom row of tiles where there was maybe a 1/8" space from the tub surface to the porcelain tiles. After removing the majority of the grout/calking, I went back and brought the surface of the tub clean of that which remained behind, at the wall. I used the blade while moving it up and down, where it rested on the tub surface at the wall tile, over a 10-15 degree vertical arc from being parallel to the floor. The fine teeth did a good clean-up job of whatever grout/calk was left, clinging-onto the tub. No marking/scratches to the tub porcelain.
My onerous job of material removal and preparation for the new calk went from a lengthy PITA to a very-successful and quicker surface cleaning. A good wipe to remove any dust, and it's time to break-out the DAP caulking tube. Careful application, and it's all-over but the wait for the caulk to set. I kept the tube cut for a smaller aperture, so the caulk was sufficiently applied to water-seal the gap, but not wide and smeared, or sloppy.
I call it a 'win' for the oscillating tool I've had for years, best I can recall, maybe 18?
Full reveal: (Caution! Results may trigger brand revulsion or performance envy) I used a Harbor Freight-sourced oscillating tool, and it was corded! (Horrors!)
PugetDude
Superstition Mountains, AZ
I have 4 OMt's
(2) Milwaukee M12
(1) Ryobi 18V
(1) HF corded 20+ years old.
The HF is a go-to workhorse for jobs that require extended runtime.
Etchase
Hawaii
I don’t use hex shaft drills that often, and drill extension even less, but Lowe’s had this on the deal of the day a week ago for five bucks, so I picked it up.
The packaging is copyrighted in 2009 and Stanley bought Newell Brands tool business in 2016. The tool industry sure does make stuff in large batches!
capm
Listed as a 0.15 ton auto jack, lol, but this seems like a good price on a lift jack copy1789129137258.png
I suppose $17 is a good enough price. But that will barely lift 0.015 ton (30 pounds).
It's patterned after, and no stronger than, a cheap caulking gun.
I grabbed a pair of similar big box jacks when my DeWalt construction jacks weren't handy.
First one broke immediately, second was tossed in the dumpster on leaving the site.
There really isn't a good use case for something this flimsy.
Shocker
Olympia, WA
I am going to have to disagree somewhat on those jacks. I just lifted the corner of a electronics bench with one and it weighs about 400lbs fully loaded. It was a heavy lift but it did it.
I will agree that they aren't as nice as the DeWalts or other name brands but they aren't $150 for a pair either.
