Astro nano socket back holder for ratcheting wrench use
centerknurk
Picked up some 3/8" Asto nano sockets that I plan to use with my VIM 17mm ratcheting wrench head. Problem is, I need the little backer adapter to keep the socket on the wrench if I turn the wrench upside down. Olsa makes an adapter set but it's a little pricey for what it is. I saw a guy on here selling what looked to be 3d printed plastic ones but I couldn't get a response from him. Anyone know of a cheaper option? Here's the Olsa ones: https://olsatools.com/products/clip-for-stubby-impact
nafets47
That adapter from Olsa is actually a very cool idea.
$26.87 for 3, that is a approx $9.00 a piece. If you buy it from their tiktok shop, whatever that is, you get free shipping but the price is a bit over $33.00, again not a bad price for 3.
How much do you think it would be ordering from someone 3D printing in plastic with shipping? If they are plastic they will just break...
C
centerknurk
I need just the 3/8" so that might be the cost issue.
Roger.donaldston
couldn't you use basically any add-on socket spinner to accomplish this? good idea, I need one now.
Who makes the 3/8 and 1/2" with the thinnest disc?
Dumber than lumber
This is Garage Journal. We agree that you need it.
Some CSOB among us who knows how to save a buck should chime in.
Isn’t there some kind of ratcheting knob that would sort of work?
EDIT: does this “finger ratchet” look close
https://www.amazon.com/WINTOWIN-Thumbwheel-Ratchet-Finger-Wrench/dp/B0C1ZZCCB7/?tag=atomicindus08-20
Or…
https://www.amazon.com/Mesee-Revers...rewdriver/dp/B0DG8GZ7GM/?tag=atomicindus08-20
whateg01
doo dah, kansas, usa
I'm assuming that the reason for this set is because of the shallow height. Most spinner knobs are kinda tall, defeating the purpose.
I can make you one but it'll cost ya about $500. Maybe just buy the one that's easy to buy
terrific
It would look a little goofy, but I'll bet you could grab a clip off a socket rail and use it the same way.
1320
Arizona
That's what I did. I used an Ernst rail clip and cut down the rail grip part as best I could. It isn't perfectly out of the way, but it worked for what I needed.
JradM
Alberta
Look for "low profile socket adapter" on Amazon. There are a variety of options.
When you're not using them as adapters, they don't even need to be especially good or tough.
WhataTool
I have some, they only retain with magnets. Weak ones. Which means the adapter reatins to the wrench, but nothing is holding onto the socket, as in nothing at all
JradM
Alberta
Bummer. I didn't realize. There are other versions from OEM Tools and Titan, but they're not quite so low-profile:
Titan
OEM Tools
Also, in-line with the idea of just using a socket rail clip, I spotted some that look particularly close:
Those particular ones are called "Reniteco 10-PC ABS Socket Organizer Clips for 3/8 inch Drive Aluminum Magnetic Sockets Storage" on Amazon, but I doubt it's the only game in town.
KnurledNut
n/a
As you guys keep searching for the perfect mousetrap, keep in mind these sockets are impacts and don't have recesses in the female square drive to mate with a ball. As is commonly the case with impact sockets, there is a hole for pin retention but it's quite large and causes more play with any ball retention method.
drokihazan
I can't think of a better solution than just 3d printing something that's a pretty snug fit and has flexible tabs to hold tension in the socket. I think I could draw something like that up pretty easily.
