scott37300
I bought a pressure tester and have a couple questions about using it.
First is are there any tips or tricks to finding a leak once you see it's losing pressure besides just seeing coolant come out somewhere? Or is seeing coolant come out about all you need? What about internal leaks for head gaskets and things? Any other signs or things to watch or do when doing a pressure test to diagnose things or pretty much just pressurize and look for leaks?
Also I read to take the plugs out when doing a pressure test because if the coolant leaks into the cylinder during a pressure test you can cause damage to the cylinder. So should I take all plugs out everytime I do a pressure test or is there only certain times I need to take the plugs out? Seems like a pain on some vehicles to take the plugs out just to do a pressure test but sure wouldn't want to cause more damage.
