signcrafter
- Joined
- May 9, 2012
- Messages
- 12,684
Today I was cleaning some tools up after doing a transmission fluid and filter change on a 2019 silverado. A dozen or so more bolts and I could have pulled the trans out since they run the exhaust crossover right under the trans pan so have to remove the exhaust on these 8l90 trans. Filled it back up using one of my fluid extractor/fillers, just a cheap one from amazon but works good. It was a messy fluid change so was cleaning tools up with brake cleaner and the pressure gauge on it is "frosted" over now and can't read it. This also happened to a dial caliper I have a few months ago. I don't remember the brand and don't have it with me, it's not a starrett but think it might have been a mitutoyo. Same thing happened to the plastic(guessing) dial cover. I was using it to measure something and grease or oil got on it so I wiped it down with some brake cleaner and it messed the dial cover up.
Is there a way to fix these at all or do I need to just get a new better gauge for my fluid pump and look into replacing the dial cover on my caliper?
