Walmart Clearance
ATC
VA
I was with dad today getting some oil for his truck, when I noticed that all of the Hyper Tough jackstands, Black Jack bottle jacks, floor jacks, and even creepers were on clearance for 40-50%+ off. I snagged a $67 pair of 4-ton jackstands for $31 (online says $35).
These are the stands I bought, but I can't find any of the other ones on their website. I didn't think to take pictures of the shelves and price tags while there either...
jayemm
up high down low
That's a decent deal for quality jackstands. Those appear identical to the other 4 ton "quick lift" stands at Advance Auto , Autozone and other places. I have the TEQ brand from AA and the metal gauge is heavy, welds perfect and little side to side slop of the ratchet bar.
Steel_Rain
Old thread, but here it goes. Also, this is VERY MUCH a YMMV type of deal...
These may be complete shite, but for $50 bucks and free same day delivery, I was ready to find out:
Sold out so fast in my area. It went from 5-6 stores have 1-2 of these each, to nobody very quickly, so as I already said, YMMV.
Good luck.
T45
The
Good luck.
Hyper tough roll-cab is looking now like its OOS. My order was taken but later cancelled as NLA.
Great deal though...even if its not perfect quality, $50 bucks...you can use it for lightweight organization of stuff like detailing, consumables, if not heavy tools.
Post up a review when you get yours.
Cruzan80
Denver, CO
I have a clone of this one, seems to work well. Same size, seems like fewer wave options, but cheaper.
David99
Treasure Coast, Fl.
Just ordered one, my current one is 10L & 240 watts with manual controls and has a deeper not as wide tank (about an inch deeper and 2" less in width) but the depth has never really been an advantage. now I need to find 2 equally nasty test subjects!
This vise grip clamp barely made it in the bottom of the basket spread open (bar was removed) for a quick evaporust bath in my current ultrasonic, the extra width in the new one will be useful.
Bunsen Honeydew
New York State
They canceled it last night around 9PM, no reason given. Bastards.
Well, claimed to be one in stock at the next closest store to me, so I placed the order today. I'll pick it up tomorrow, unless they cancel.
Waiting for the email either way now.
We'll see. I need some storage for odd stuff in my shed, so maybe.
Better than those plastic stacking drawers.
Edit. Received confirmation that it is ready.
catalytic
Boston, Los Angeles, Cleveland
Run it with hot water, some evaporust (which dilutes fine), and dishwasher powder. I run Crest ultrasonics that way and they are incredible for machine tool restoration. You will want various sieve-like things for your nuts and bolts. Ross/TJ Maxx has stuff like that in the cooking section.
hammlm
SE PA
I got mine too and put it through some easy paces on Saturday. I love the larger capacity. It is a bit noisy, but I can live with that for $50.
trekgod3
Jupiter, Florida
FYI, mini toolboxes down to $8. Got the last two at my store. Also big rolls of brown wrapping paper for $1.25, Also radar detectors and car speakers, lots of smart light bulbs, spray paint, paint gallons, all kinds of stuff.
Butters
I grabbed one to do that as well, but then I realized it's only 4" deep. Hope it works out for you!
While those dimensions match the basket, I'm wondering if you can't go higher. The container depth is almost 6". The directions say don't go above the "max line", but there is no indication of a max line on the washer itself. The basket is also elevated a bit as well. Point being, if I had something to clean that was 5" (insert joke here), I am pretty sure I could make this work fine, especially with a different basket. Do you need to use a basket while operating this?
Aileron
outside
Maybe this isnt the spot but mine came yesterday. Haven't opened it up yet. I used stoddard solvent parts washers, carb dip etc but have never used a ultrasonic cleaner. They just seemed to me to be too small. For the price on this, i'll give it a go as a starter and maybe buy a bigger one when the time comes. Do you buy the special "ultrasonic cleaners" or just used a dishsoap? I have a carb off my honda snowthrower thats been sitting as I had some fuel issues and it was just as easy to replace it years ago.I replaced it with Honda carb but started to have issues with the gaskets. I am going to try and clean the old one up and put it back in service. What the best chem to use on the carbs? Like i say i'm just starting with these , so it will be my trainer. I was reading about the glass jar and plastic bag tricks to keep the water clean.
Chuckster in NJ
Hunterdon County NJ
I use distilled water and put my parts in a glass jar or plastic bag along with the "PROPER" chemical for the job. I clean a lot of gun parts so I use a gun cleaning solution and put the parts in a plastic bag so the water stays clean.…….. The solution in the bag gets dirty so I dump it and blow the parts off to dry them and lube them right away prior to assembly.
TIP! Use the proper chemical or detergent because some chemicals are highly corrosive.
gimpyrobb
Cincinnati
With mine, I put the stuff I want to clean in a glass container with the cleaner. Keeps the tank from getting funky. I guess if you do large parts that option is out of the question. I prefer to use ATF but a lot of people use simple green or pinesole.
