Pole Sander for Drywall?
karoc
Hemphill Tx
I need to get pole sander for drywall. I’m familiar with the 3.5x9” pad on pole.
I started looking check on price at big box stores. I see that there’s now a 9” round sanding pad that cost about 45.00 then have buy pole seperate.
Wondering if anyone has use these round head pole sander and if they think it’s worth extra money? Thoughts?
Hakeem
Chicago
The traditional rectangle sander can flip over and mar the mud if you’re not careful, the round ones are supposed to avoid that.
If you have a lot to do and you’re skilled with finishing drywall, the round sander is probably better but it’s a little harder to target “oopsies” than with smaller sanding pads
Firebrick43
West central Indiana
Based on several drywall contractors advise I got a trim tex black widow pole sander. Its so much lighter than a traditional net sander and faster as well, needs hardly any pressure. Of course the down side is that you have to use their hook and loop pad/paper, but its worth it.
It doesn't leave swirls like every rotary sander I have seen does when casting light down a wall.
DGersic
DeKalb, IL
Round works better than rectangular. Less likely to flip as you sand. The job *****, though.
The powered one from HF works well. I did the ceiling and walls of my living room, several times as I was skim coating it over plaster. Dust collection worked well. Still a shoulder workout.
The Cobbler
when I was a contractor I reneged on buying a power pole sander .
I got one cheap at princess auto that was a store return.
after 2 minutes of using it, I wondered why I took so long to buy one.
I then bought a powered (non Pole, hand held) sander to add to the Arsenault .
money wise spend if you do any amount of drywall
K
karoc
Hemphill Tx
Going check into this, and others that was suggested. I do have lot sanding, so may be worth investment. 👍
signcrafter
I have a couple of the radius 360 ones and they work good. They don't get into corners like Cam mentioned but they do make a triangle version for corners that I also have but don't usually use it. I use the 360 to do as much as I can and then run a foam sanding sponge made for corners up and down a few times and it's good.
I bought a HF electric pole sander a few months ago and love it. Works great and goes on sale for 100 bucks regularly. Well worth the investment even if you're only doing one room, especially if you have a good vacuum it will leave very little dust. I've been finishing drywall for over 25 years and used to hate doing it. But with a mud tube and the heads for inside and outside corners along with a couple flat boxes and the electric pole sander now I don't mind it too much. I spend more time cleaning tools then actually mudding.
gizardlizard
Madison, WI
Radius 360 sander is awesome and super fast. Anybody using GP mud for second and third coats is creating a lot of work for themselves. Use topping mud and it sands so fast. Electric is overkill.
Beerhippie
Far NE Oregon
Pole sander for drywall? All the drywallers around here are Hispanic.
My brother hung wall paper for a living. I worked for him one winter back in the '90s and he had the first power pole sander I'd ever seen (drywallers never get the wall smooth enough for patterned wallpaper). It had a linear motion instead of rotary, so no swirls, and was about a foot long, making feathering outside corners a breeze--and dust collection, which was a joy to use.
K
karoc
Hemphill Tx
Do you know how to properly thin your mud? Once you have that and feathering down, there’s hardly any sanding to do.
Watch some YouTube’s (Drywall with Kenny) and learned difference between green and blue buckets. But I’m still all ears open for suggestions
Thanks to all for suggestions
rust in the eye
Chicagoland
First time I've seen drywall and "joy" together.
signcrafter
Green bucket or all purpose is for taping and first coat. It has some kind of glue or adhesive in it to help with the taping. The blue lid or topping compound is for your next coats. It goes on smoother(when you thin it with water like Cam had mentioned) and it doesn't shrink as much and is easier to sand. Then you have hot mud that comes as powder in a bag that you mix with water.
I will use a 45 minute hot mud to prefill any gaps. No matter how good you are at hanging there will always be a few gaps in corners or where a corner of the drywall gets busted out when hanging or screwing it. If you don't prefill any gaps you will have issues when taping. I use fiberfuse instead of paper tape for most things, It's a lot easier to work with then paper especially for beginners. Everybody has their own order of how they tape and mud and mine changes depending on the project. Because I want to try to get as much done as I can before I have to let it dry. Doing a single room for someone else can be a pain because there is only so much you can do before you have to let it dry and find something else to do the rest of the day and then come back a few times.
There are also 2 types of drywall finishers, those that use a pan and "knife" and those that use a hawk and trowel. I started out using a pan and knife and what I'm most comfortable with most of the time. I did get into the hawk and trowel a long time ago when I had to match a skip trowel sand texture in a restaurant. I liked it but usually go back to the pan because it's what I spent the most time with in my hands.
Inside corners take the most time because you do one side at a time along with your 3way corners. I ended up buying what they call semi automatic tools over a decade ago and they cut that time way down since they can do both sides at once. I don't do enough to justify an auto taper like pretty much every drywall finisher uses now. I use a banjo most of the time for getting the tape onto the wall, saves a lot of time. I did buy one of these and it works decent for the inside corners, https://www.amazon.com/Advance-Equipment-Hand-Corner-Flusher/dp/B084KKNQ79/?tag=atomicindus08-20. It's similar to my much more expensive corner flushers on a pole do. If you are doing a decent amount of finishing and want to spend some money vs time look into corner flushers and a mud tube. They make it so easy to finish corners, like I said I spend more time cleaning my tools usually then the actual mud and taping. They aren't crazy expensive but hard to justify unless you're going to be using them a few times a year or big project. I try to add another tool to each drywall job I have over the years to cover the expense. Flat boxes and other tools add up fast and are hard to justify unless you are making money with them. But a banjo and a couple flushers aren't too bad and really make the job a lot more enjoyable.
