overdriv
I am building onto my garage. Going to heat the new edition with radiant under the slab. The old garage is heated with a ceiling mounted propane heater that does a very good job.
I plan to remove the wall between the two. Also I plan to have some kind of curtain separating the two to keep the dirt out of the old garage which will be cleaned up and used for parking our car and pickup.
I'm hoping the radiant heat in the new part will warm the old garage enough to finally eliminate the propane heater.
Both parts are insulated, new part better than old. Both doors are insulated.
The new part will mainly be for working on the hot rods.
Using the simple heat loss calculator in another thread, I figured the heat loss on both sections and came up with 29314 BTUHS.
How big of NG water heater would I need?
