OLD Snap-On Ratchet
BiltFordTuff
This is my grandpa's ratchet (snap-on) that he got from the army back in the 30's or 40's. It is still a good ratchet and its the only one i've ever seen, does anybody have one like it?
Bruce Lancaster
I've got several of that general style. I believe that shape of handle was used for both industrial and military ratchets (also some Blue Point and Par X stuff!)...military usually have no date code and has a "V" in the part number...
It is mechanically the same as regular ratchets of same time period, and I believe the ones with same head and repair parts also have the 71 in the PN.
I have kinda sorta started collecting military Snap-on, both the WWII E and G type and later stuff with handles like yours. So far, sort of groping in the dark with no relevant catalogs and no date codes on the tools.
Deskmechanic
Long Beach, CA
I have one and like it. They made reproductions of it a few years back too.
Unfortunately they don't have rebuild kits any more. Mine has a bad tooth and snap-on doesn't have the parts. If it's a non-military one you can send it back for a replacement S80 ratchet, but the e/g date code ratchets are not eligible.
csp
Franktown, CO
I have one that needs a rebuild kit. My grandfather used it in the 40s as a mechanic at a local Ford Garage.
4x4gearhead
New Hampshire
So that would explain why I couldnt find the date stamp and it is FV71 kinda makes it even cooler, p.s. I paid $5 for it with a few things in a yardsale and it is in very good shape
BiltFordTuff
Back in the 80's or 90's the Snap-On guy replaced the guts inside our ratchet because it was stripped and worn. If you look closely at my pictures you can see a difference in other 71N's.
