Fedwrench
The UPS man delivered my 1/4 and 3/8 drive Craftsman premium ratchets this past Tuesday. I took them to work and used them for a few days. I like them. I particularly like the way the handle feels in my hand. They're strong and smooth. Now since I am a trully sick individual, I was wondering how the Craftsman 84 tooth ratchet compares internally to the Matco 88 tooth ratchet so, I played doctor Frankenstein and took them apart, swapped pieces, put them back together to see if they would work. they did.
The ratchets share the same basic design and many components from the 17 tooth pawl, to the spring loaded bullet shaped plunger, to the orangish o rings sealing them. There are also some differences too. The pawls are marked 84 3/8 or 88 3/8, the slector switches are finished and shaped differently. The inside of the matco 88 tooth ratchet body and rear of the gear are smooth. However, the inside of the Craftsman 84 tooth ratchet body has a raised circle that meshes into a cut out circle on the back of the gear. For this reason I wouldn't recommend trying to upgrade your 84t to an 88 tooth model (even though you sicker individuals are thinking about it right now). Lastly, the Matco cover plate consists of the standard thin steel cover with a snap ring. Whereas the Cratsman 84T uses a thicker cover plate secured by two T6 screws. I would really like to see a flex head version in the near future.
