Horses Ghost
I have a 15 year old craftsman 5.0hp shop vac that is in need of replacing. I used it for cleaning the floor and some vehicle use. What should I buy? Thanks...Mark
NOTHING that hooks up to a standard wall outlet is 5.0HP or even close to it. Do not fall for those totally bogus HP figures on stuff. 5.0HP takes 56Amps and a 90A CB on 120V, or 28Amps and a 60A CB on 240V. Theoretically you can run 1HP off a 120V wall outlet but the practical limit is ~3/4HP.
I totally agree, but I already made a bad choice on one, and I don't want to make it on the second
I had a 16 gal Shop Vac for close to 15 years and the switch broke. I called Shop Vac and they sent a replacement switch but it wasnt the right one. Turns out the switch that I needed was discontinued. I used a toggle switch for a while but it was rigged and I didnt really want to use it that way. I bought a 14 gal Rigid from HD. Not as powerful as the old one but it will do. The only thing that I really dont like is the way the accessories store. It has a bag on the back as opposed to the setup on the Shop Vac which I feel was much better. But for the money its not a bad vac. Its picked up everything so far but I havent used it on liquids yet.
For the average joe at home, a Sears or Rigid shop vac will do just fine. Get the optional soft flexible hose, and not that black plastic one that is hard to work with, on second thought, get two hoses and connect them together, gets the vac further away so you don't have to listen to it. They are all noisy. If not noisy, they are expensive, way too expensive. Second thing to buy is the Gore filter, the more expensive one of the two (Cleanstream), made from the Goretex fabric. You just shake it out, sometimes I hose it off. Never brush it or scrape or rub it, it will get damaged if you do, just shake or hose, it looks like new when you are finished.
Charles
Let me get this straight. You had a perfectly good working shop vac that you ditched because you didn't like having a functional toggle switch on it in the place of the original switch? Why? When the motor burns up, then I will consider a new one, until then, if something like the switch or cord needs replacing, it will get whatever I can make work functionally and safely.
Charles
