Nut Drivers?
littletoes
NE Washington
Am I one of the only guys that use 'em???
I use 'em at work all the time, but don't have a set in my home tools.
If you guys use 'em, what do you like? How 'bout the magnetic version?
Thanks for the help guys!
sawatch
Southern Colorado
I've got a set of Proto's that are great to have/use when needed. I've used them a lot more than I thought I would have, over grabing my 1/4" drive stuff.
willf650
I use them al the time at work, at home not so much. Allot of the equipment I work on use a mixture of 1/4" , 5/16" and 3/8" headed screws. I like the klein magnetized ones myself. I do keep a hollow shaft 10mm in my bag for clamps on actuators I mess with regualrly.
Fedwrench
Valley of the sun
Except in areas where clearance is an issue, I use magnetic nut setters on the end of a CT561 cordless screwdriver more than any regular nut driver.
sberry
Brethren, Michigan
I have several sets, would be lost without them, tool of choice if applicable. Use 5/16 and 7/16 a lot, just added a couple more 10mm to the collection as I am doing more auto work these days.
Honda 1
I have the Craftsman versions. Both SAE and Metric. I use them fairly often and like them.
They have saved my bacon on a few occasions.
The Craftsman sets when on sale are a good value for the price.
Jim C.
I seem to use the 10mm and 1/4" more than any of the other sizes. Nut drivers are not usually my "go to" tools, but like any other tool....... When you need one, you need it, so a few basic sizes are good to have on hand.
plinker
Northern Wi
I have 1/4 & 5/16 Craftsman for hose clamps & misc. stuff at home. I did pick up a 10mm recently though.
sberry
Brethren, Michigan
If anything, a 5/16" is handy for hose clamps.
I got a guy that worked for me just couldn't understand why I threw out perfectly good hose clamps,,, if they are not 5/16 I don't want them. (of course the smaller ones are 1/4 and there is no way around that but toss a lot of those as well in favor of spring band clamps) When I see clamp I want to grab one tool, buy many extra nut runners just for them. Have hundreds of clamps, don't want odd ball sizes.
Scout Driver
South Dakota
Very true. Lately I've noticed at the stores with open-stock nutdrivers, they are usually out of 5/16". Do you have all of them?? :spit:
Scott
NOTABLAZER
I use them all the time,I just have a cheapo set that I got from carquest. Works fine and has a lifetime warranty.
Recently I couldn't find my 5/16 from that set so I grabbed this POS that was in my tool box just to tighten up a hose clamp (you know the type of screw/nut drivers,with the clear colored handles). Well once the clamp got snug,the handle shattered in my hand. I tossed the rest of those shortly after that :)
JayL
Manila, Philippines
I purchased the Craftsman metric nut driver set ( good quality ) but don't like using it much. Maybe because the handles are a bit small for my liking.
Thinking to get myself some T-Nut drivers soon.
Scout Driver
South Dakota
I have a Craftsman 1/4" drive socket set with a sliding T-bar. The T-bar is actually comfortable to use, especially with a long extension.
Scott
RbrtAWhyt
North East Georgia
Since I got a set of the Craftsman T-Handle nut drivers I don't think I'ved touched my other nut drivers. I really like using them when practical...
Indy_500
Appleton, WI
Get yourself a nice set of nutdrivers for Christmas! xmas
At least try a 5/16" socket on a 1/4" driver. :)
Scott
i could try the 5/16" socket on a 1/4" driver, but a screwdriver is quicker :) i'll maybe ask for those some other time, they are something nice to have. I need other things first like bigger air compressors, top box, and a welder.
Sh1thead
Philly :(
I use them all the time at home for stereo and interior work but seldom use them at work for anything outside of hoseclamps
gatewaysysop
Arizona
x2 on this. They're definitely a good value and, at least mine, are US made. I actually like the zipped pouch they come in too. Definitely get them on sale though. Speaking of which, I believe they're currently on sale. :thumbup:
baubau
i use 7 mm, 8mm and 10 mm all the time in autobody shop.....it is one of my "go to " tools when fitting new panels on the cars, especially cheaper steel aftermarket parts so that i dont strip the threads....i also have gearwrench metric nut driver set that i use a lot....
but has anyone tried this?.....
http://www.aetools.com/products/hazet/basic-tools/reversible-t-handle-ratchet-wrench.html
now this looks both speedy and controlable ....
MrMark
Southern Cal.
nutdrivers are great for working on equipment, appliances, lawn mowers, hvac, etc., where you know most all fasteners are low torque 1/4, 5/16 or 3/8. I like to just put those three out and then you can just grab and go. Nutdrivers are a great convenience item and they add speed to the job.
I prefer Wiha hollow shaft, but the Klein with the mag tip are really nice too. I have three lengths of the Klein in 1/4 and 5/16 for doing electrical and the mag tip comes in handy on other applications as well. The Klein stubbies are awesome and essential for working on light cans.
Krokodil
South Africa
I've got a wera hollow shaft set. The thing to look out for in nut drivers is really the hollow shafts. I use them a lot with my 1/4" dr ratchet on the other end when tightening bolts with nuts.
babewatcher
East
Don't own any, actually never used any. Sometimes I'll put a deep well 1/4 inch drive socket on a 1/4 inch spring flex shaft screwdriver type handle but that's as close as I come.
JayL
Manila, Philippines
Unless clearance is a problem I think these would be a better go to set than the screwdriver type. Of course it's still a matter of personal preference and others might still like the screwdriver type more. I too like the screwdriver type but there are times when I find I need more torque to break a fastener and find that hard to do with my craftsman set.
This is the one I have.
http://www.sears.com/shc/s/p_10153_12605_00904197000P?prdNo=5&blockNo=5&blockType=G5
Lump
Jamestown, Ohio
I LOVE nut drivers. Very fast and convenient to use. Hose clamps are just one obvious application. Me like-um nut drivers!
Hal
Vermont
I have at two in 5/16. My maple sugaring equipment and pipelines are loaded with hose clamps. Flat blade screwdrivers are a poor second best choice. Any odd sized clamps get flying lessons about the first time the screwdriver slips on them.
sberry
Brethren, Michigan
I ask the guy at a supply house about that, he says,,, well as soon as we get a couple in they are sold, I said,,,, you ever think about ordering a couple extra?
babewatcher
East
But, wouldn't a 1/4 in ratchet with an extension and a 5/16in socket be ten times faster? :confused:
