Re-use lumber from footing forms?
ForceFed70
BC, Canada
Can you guys think of any reason why I couldn't re-use the lumber from the footing forms? Was thinking of using 2x6's for the forms, then re-using the 2x6's for the building walls.
They would likely have some concrete residue on them and will have been coated with a release agent.
LEVE
On the Willapa
I used all the form material to build shelving, a workbench (with shelves) a tire rack and a rolling cart.
The residue doesn't bother me... I can knock it off, sand it down if I want and paint. But heck, it's a garage, so it looks like a garage - not a showplace.
nehog
Jaffrey, NH
If you are in the northern areas, get an 'ice scraper' used to scrape and breakup ice on sidewalks. They work wonders for scraping off the residue from the form boards. I'd reuse 'em anywhere they are not visible, assuming they are undamaged.
simonac
there is no reason not to do it.... if the lumber is in good shape y not!!! this is how they use to build house in the old days thay would use 2x... for the form and then reuse the same lumber for the structure and what not..... this is exactly what i did when i built my garage.. my time is cheap and building material arent free...:shocking:
jhelrey
MN
Drop them a few times and the concrete will fall right off. The rest can be buried in a wall.
Stuart in MN
Minneapolis
The floor joists in my house were used for forming the basement walls; I can stand in the basement and look up, and still see bits of concrete hanging on them. It was built in 1913. :)
F
ForceFed70
BC, Canada
Sounds like I'm safe to re-use. Thanks guys.
I plan to rent the stem wall forms, so it's just dimensional lumber that I plan to re-use.
tfi racing
Cedar,BC
Take a look around,it is done all the time around here,at least on the island.The 2x's are used for blocking,cripples and all the random pieces you will need,I don't know if I would reuse them as studs though.I see a lot of projects that use 1x's for the concrete forms,then reuse them as sheating run diagonally,had I known more at the time I would have done that instead of paying 900 bucks renting forms.
lupinsea
I'm really glad I rented the stem wall forms for my shed foundation pour.
I was planning on re-using the footing form board but that didn't happen. Word of advice, don't get lazy after the poor. Strip the footing boards when the footings have firmed up (a day or two or so). My time was so short working on my shed this summer I kept thinking "bah, I have more important things to do like setting up the wall forms, I can strip the footing boards later".
Errr, wrong.
Some of the concrete from the wall pour slopped over the side of the wall form, it didn't get cleaned up, so some of the footing boards on the exterior will become part of the back fill dirt in due time.
Bottom line, if you want to re use the footing board, pull them off and clean them up as soon as it's feasible. And try to scrap off any wet concrete you can while it's still wet.
Oh, and another tip: while the freshly poured footing is still wet, set the bottom form panel clips. I figured I could nail in the clips a day or two later while the concrete was still green. I did, it worked, but it was a bit harder.
And . . . tip 3: the more perfect, level, and smooth you get your footing, the more accurate will be the wall form. The tops of my footings were screened level but they weren't smoothed over with a steel trowel. I should have done this. Then set the form clips.
This was not smooth enough for my tastes. It would have made things a bit easier on wall framing if this footing was smoother because the rental panels would have had a more uniform top sitting on this. Each phase affects what happens down the line. The more you sweat the quality / details up front, the easier the next step will be.
Oldtymeflyr
Littleton, CO
In the 1960's and 1970's some homes in the Denver Colorado area have floor boards from the 1x6's used for foundation forms. We had a nice home in Lakewood built that way.
:3gears:
