Compressed air flow rate?
JustBob
Mobile, Alabama
Anyone know how to, or the location of an online calculator for determining compressed air flow rate through multiple tubes in parallel?
Example: I was thinking of using a 4.5 ton air handler to make a compressor after-cooler, it has the motor, fan, and coil already boxed. The coil I want to use is a W shaped instead of an A coil, and the air would flow through 8, 1/4" inside diameter tubing simultaneous.
3/4" inlet tubing, branching off into 8, 1/4" tubes, then combining back into 3/4" for an outlet.
If the calculations come out ok, I will go ahead with the build since the equipment is free.
:headscrat
Stinger
Basehor, KS
I wouldn't count on you finding any calculators that calculate what you are asking. First step would be to calculate the internal area of the 8 tubes vs the 3/4" inlet to make sure they don't cause a restriction.
MattT
Pretty much. Isn't just the cross sectional area that affects flow though. You've got to figure the bends too.
Also for a cooler you need to watch velocity. The cooler ain't gonna do you any good if the air is running thru' it faster 'n' a scalded dawg.
J
JustBob
Mobile, Alabama
I am pretty sure I was overthinking this, since an aftercooler goes between the pump and tank. The pump to tank line is only 1/2", so I believe 8, 1/4" lines should not be a problem for 12 cfm.
The coil has 10 square ft total area, with 146.6 feet of tubing. Each line is18.3 feet in length. It should have a lot cooling capacity... :headscrat
Since the parts were all free I will go ahead and build it, if nothing else just to see how well it works. I can post up a build thread after I get started if anyone would be interested.
MattT
For 12cfm you're good:thumbup:
larry_g
oregon
Is your air handler rated for the pressure you will be using?
lg
no neat sig line
J
JustBob
Mobile, Alabama
lg
no neat sig line
Yes, all tubing is ACR grade, good for 1100 psi for 5/16 tubing. I will be brazing the incoming line fittings, and then siver soldering the new manifold on the outlet side. Inlet temp will be 300 F, reason for brazing instead of soldering.
J
JustBob
Mobile, Alabama
Just for future reference.... a real basic calculator.
http://www.gates.com/industrial/pressure/airFlow.cfm
Thank you, just what I needed. Using that calculator, and dividing the total cfm by 8(1.56 cfm each .250 line), it shows a pressure drop of .20 psi. It should be good for future upgrade as well, at 24cfm/90psi it shows a pressure loss of .73 psi. At 175 psi/24cfm it shows .4 psi drop. :beer:
