Owen
HD has an 80gal 2-stage compressor for $799. We need to buy a refrigerator and would get a rebate of around $200. Would this be a good compressor to buy? The rebate would really help in the price department!
Hey you fly RC planes
I used to do that!
I don’t know, but they kept drawing excessive current tripping the breakers. I forgot what size breaker, but I even went 10 amps over rating. I couldn’t get the compressor to go over 60 psi if I recall and this thing was brand new. Service tech couldn’t even find anything wrong. He just said they were junk motors as was the rest of the unit.
One bum motor I can see but two having the same odd problem? From your description it sounds like a voltage drop or droop during run.
Two bad motor's in one month, I would have went ballistic on the someone.I've wired my quincy into the exact switchbox the CH was wired into. I've been running it for several years now with half the fuse and never had a trip out. I've had the quincy running in full toot continious mode doing several sandblasting jobs (car frames / outdoors) and never a burp. Just junk motors on the CH drawing too much current because they were undersized for the application.
Again my opinion. Draw your own
Regards,
Rick
Well, its sold as being a 5hp compressor, but the motor isnt big enough to really be true 5hp, and the pump is very small for an 80 gal 2 stage 5hp. It is a USA made pump, and its not a bad compressor at all, but the specs they give are pretty innacurate.
If your running air ratchets and impacts, Im sure it great. if you want to run air sanders, you may not get enough CFM out of it, and it will run a lot as well.
Forgive me, could you elaborate on how you came to this conclusion? What exactly you looked at to know whether the motor is "true 5hp" , etc. It would really help knowing what to look for.
Thanks
Regards,
Rick
Hmm, that makes sense I guess. Also, the HD site didn't have the same compressor, they have a 7hp one though. Couldn't find specs on the motor.
Northern Tool has an IR compressor #1592012A (model 2340N5) 80 gallon for $1300, which is a little over my price limit. Maybe I'll get a 60gal one.
So where do I find the amp ratings for these units online? And is that start up amps?
Thanks
