What kind of wall cabinets are those?
Looks like a great start! How deep is the garage?
But in the time it took to put up those banners, you could have painted one of the wall sections.
What was nice about the pre-banner pictures was how clean the layout looked with the two-color cabinets and the neutral-color wall. I think a bunch of art/photos/memorabilia are going to undo that clean look.
What we used to do when we rehabbed apartments was to mix drywall mud and paint together and paint the walls. You can vary the consistency to get a light texture but it will cover bad seams. a couple of gallons of drywall mud and a gallon of latex paint mixed well should fix you right up. You can also go over your existing seams if they have real high rough spots with a wet sponge to knock it down some instead of sanding.
I thought about a "textured" finish. How does your mixture look after it dries? Is it rough like sandpaper? Or does it smooth out? How do you apply the mixture to the wall? It really doesn't have to be that thick, just enough to cover all of the flaws...
No way would I even attempt to mess with it myself if I was paid three times that amount. This guy will be in and out in three days juggling two other drywall jobs with it. A drywall finisher at slow times can be very reasonable in price.Instead of spending a bunch of time and money trying to repair the wallboard taping and then mudding and painting everything, is there any other material out there that would be economically feasible? Perhaps prepainted sheets as used on semi trailers? Any other reasonable suggestions would be welcome.....I do not want to work with the wall board.
Looks good and I dig the Sonic Blue SVTF.
Yes, it wasn't until after I posted that I went back and saw the ceiling was the same way. My ceiling isn't drywalled, and I seriously doubt I would bother with the ceiling myself. Can't blame you on that one.I guess I am ok with the walls, after I blow in some insulation, but the ceiling is the real PITA.....lol I could get enough scaffolding to put me up high enough to be like Michealango and lay on my back???
Thanks, here is a better picture...
