...due to people plugging cord reels into the GDO receptacle on the ceiling.
That's exactly where I had my cord reel connected in my last two houses! I was always a little nervous because it wasn't GFCI protected.
When I finish wiring in my new garage I'm going to have a ceiling outlet just for the cord reel (on a GFCI circuit.)
I am slightly annoyed by the NEC 2008 requirement that
all 120V garage recepticals need GFCI protection, because (if I understand correctly) that includes my 6 ceiling recepticals for my 12 two-tube 48" T8 hanging fixtures. If I have two 15A dedicated circuits for lights, thats another $50 additional cost for two more GFCI breakers (I want to use GFCI breakers rather than the admitedly cheaper recepticals.)
However, GFCI protection for the lights might not be such a bad idea, becaue I did get a shock from a hanging florescent light fixture once while working under a car!
How the heck was that possible? Well, I was singlehandedly reinstalling the engine & transmission in my '76 Celica. I had a 1000# SuperWinch bolted to the ceiling rafters and was using the winch to lower the engine/****** as I guided it into place under the car (had the remote to the which with me under the car which made it pretty handy to lower or raise back up as needed.)
Now the winch was powered off a 12V car battery, so no danger of shock there. But all of a sudden I got a pretty good tingle! Grabbing my volt meter I measured over 70VAC between the hanging engine and the chasis sitting on jack stands on the concrete floor! What the heck?!?
Well, it turns out the winch cable from which the engine was hanging was rubbing against the metal reflector of a hanging florescent fixture, which was plugged into a (non GFCI) wall receptical using a 2-prong extension cord. The outside of the light fixture had become energized! Either a properly-grounded 3-prong cord or GFCI protection would have been a good safety measure.
So I don't object too strongly to required GFCI protection for my ceiling lighting recepticals. But I still wouldn't like it if I was going to have a freezer in the garage, although new GFCI devices seem less prone to nuisence tripping than a few years ago.
Interesting side note... for the 2008 code cycle, the state of Wisconsin made only one amendment to NEC affecting residential: you can have a non-GFCI protected receptical for a sump pump as long as a GFCI-protected receptical is available within 3 feet. (Saddly, Wisconsin no longer omits the AFCI requirement as they did the previous two code cycles.)
