16' x 24' Single car + budget build
Zengineer
British Columbia, Canada
Sanctum Machanicus
Bought the house in December of 2007, my first house. Came with a decently sized carport, 16' x 24' or so, with a cracked and broken slab. Provided some covered parking and workspace (though cold sometimes!) for the better part of 2 years.
In October of 2009, we started what was probably the biggest DIY renovation that I've handled solo. Previous to that, I did bathrooms, bedrooms, kitchen, etc. I really had no concerns about undertaking the project, I've always been able to plan and do well enough to get excellent results.
We knew that we wouldn't be in this house forever, so it was time to build some sweat equity and have a bit of space to continue house reno's in as well. Garage on the cheap...
Z
Zengineer
The existing slab was cracked and sunk, probably about 8" at one point. I decided to break up everything that was cracked or sunk, leave what was ok, and repour. (to save a bit of cash) In retrospect, I would have done things differently and taken up the other slabs as well. Not a huge issue, but the end result would have been just that little bit better.
Breaking up the concrete with the jackhammer wasn't too bad, took about 4 hours and was physically pretty demanding work. Once I figured out a system to do it effectively, it was much easier. I'm glad it was a sunny October day, and not a sunny July day however.
Pulled out about 10tons of concrete rubble, 5 pickup truck loads. Hand bombed in, hand bombed out of the truck at the recyclers.... on the cheap!
Z
Zengineer
Regraded a bit, leveled out the base, and power tamped it for about 3 hours. (overkill I hope)
I decided I was going to try to do it in 1 pour, as the existing structure was intact and everything I'd be adding was not structural, beyond holding it's own weight. In retrospect I would have had A+ results in 2 pours, but I ended up with B+ results... a learning experience, and less expensive.
Repoured 8 yards of concrete, fire time pouring it. Wasn't perfect, but I learned a lot for next time. It actually came out ok, I just expect perfection from myself... and concrete isn't super forgiving for the first timer. ;)
The following weekend studding went up. 2x4 24" OC, got a free-bee window from a neighbour.
Also upgraded the service and electrical panel to the house, from 100A to 200A. In the process I moved the panel into the soon to be garage. It made life much easier by doing that. All my new garage runs were short, and I didn't have to pull down half the house to run wire.
Z
Zengineer
The following weekend, all the sheeting and tar paper went up. A couple long days, and putting up tar paper by yourself *****. Managed to get it straight and so on, but it's a bit tedious and difficult solo. I had some help doing the peak area though.
Things go so quickly at this stage, you can really see the difference in just a day's work.
Following this (not much for photos) was interior wiring. I wired in 8 (3x3 grid - center missing) boxes in the ceiling for lighting, and put in 8 2-gang outlets around the perimeter of the interior. All these boxes (save one) were put in at 48" height to be overtop of any future benches. 1 was in the ceiling for the garage door opener, as well as an overhead reel.
In total, I put these 8 outlets on 2 15A breakers, and the 9 lights on a 15A breaker. I also added in a 220v dryer plug on a 30A and an electric baseboard on a 220v 30A breaker.
Lighting is ceramic base with 60w bulbs. ($20 for the whole garage) I would call the lighting levels average. Some task lighting will be added over benches/tools anyway, so that's just fine for now.
Z
Zengineer
A couple other notes, the ceiling height is 9'6", which is an absolute god-send. I have no idea how anyone can function with an 8' ceiling in a garage or shop!
Main door opening is 10' x 8'. That extra size has come in handy more than once.
Man door at the rear is 36". I was going to put in double doors, but at $800! vs. $149 I just couldn't justify it with the overall budget in mind.
Budget was to be $5000. I'll talk more about that as I update the thread, but it's not far off.
Motown 454
Nice job its coming to gether well. That will make a nice work space for you.
Z
Zengineer
The original plan was to try to match the stucco with the rest of the house. No much of a surprise, but the rocks used on my house in 1964 weren't available anymore. :lol_hitti
The options were to refinish the whole house (quotes around $12,000) or to go to plan B on the garage. Plan B won out, at about $800.
The hardiboard went up between Christmas and New Years, with the help of a
(great) friend. It's a bit of a pain to work with, but other than the weight and dust it's not too bad. I just used a cheap (disposable) circular saw blade and it worked quite well.
No photos of it going up, as you can imagine in late December we were concentrating on getting the job done, rather than taking photos.
I may yet paint the gable end of the garage dark brown to linet up better with the rest of the house's style. Still some work do be done beside the driveway, and around back as far as landscaping goes. Soffits yet to come as well.
Z
Zengineer
An insulated 8' x 10' door was added, I believe it's insulated at R12. Also added a belt drive opener, weather stripped the door, etc. It was important for me to have a drywalled, finished space inside the garage, so the ceiling drywall went up early on. Also mudded the section where the opener mounts so that I wouldn't have to fiddle with it again later.
I have some health issues that have prevented me from spending any longer than about 10 minutes on a ladder at a time, so the mudding for the rest of the ceiling will be a painstakingly slow process. ;)
All the walls are insulated, as well as the atic space. For about $250 in this case, it was a no brainer. Unheated it has stayed between 12°C and 24°C through the winter and summer. I've put in heat to dehumidify, and keep it around the 12°C mark during cold snaps.
Pretty nice in there today! (See thermometer)
Z
Zengineer
Still areas that are unfinished, and that is because there are still some changes to come. Around the panel, I've left drywall off because I am going to redo the room on the opposite side of the wall. Part of this will be to run dedicated lines to that room (home theater) as opposed to the current setup where those runs have other areas of the house on them.
Nothing like turning off the bedroom light breaker, and losing the kitchen counter plugs, office computer, laundry room lights and rear patio lights...?
The garage is not yet finished, but obviously is being used for a number of projects despite that. Some tools have made their way in there, and I will drywall and mud, paint, etc. at some point soon!
Z
Zengineer
Which brings us to earlier this week. I got a smoking deal on some ball bearing slide lower cabinets, at $149 a piece. Picked up 3 of them this past winter. In order to make the best use of them I wanted to put them in a bench. Steel would be my ideal, but I had some 2x4's around, and they are damn cheap.
Still to come is a 3/16" steel top... just have to get to the steel store when they are actually open. ;)
Z
Zengineer
Put a 10ga steel top on the bench earlier this week... steel has gotten majorly expensive in the past few months! $217 later for a sheet of 10ga.
I could probably get it at half that price through my old work, but it would mean a 2 hour round trip. So I have some extra steel for the next bench! 10ga is the minimum thickness I would go with, but it should be pretty resiliant. For the "main" bench I'll probably put it over top of a sheet of plywood for more support. (concerned with it denting if abused, not concerned about it failing)
Been mudding the ceiling a bit every evening for the past week... coming along. Should be able to complete the first coat of the whole ceiling by the weekend. Slow going, but at least it's going...
Z
Zengineer
Slowly, slowly the mudding is getting done. 2 coats done now, just some sanding and another coat and a bit more sanding... then comes some paint!
Also picked up a 3-ton arbor press recently, nice, inexpensive, useful tool.
Artistic
Canada
I see your a BMW fan ;). Nice progress.
Btw, are you in B.C. ? Those plates look familar, but hard to tell from the pics
Z
Zengineer
Picked up a 32"x60"x3/4" steel welding table a few weeks back, for free. It's been sitting in the truck while I try to figure how to get it out. Nothing overhead I could use, no cherry picker, nothing. Time to be creative... while moving a 600-700lbs table!
Step 1 - Build 2x4 apparatus in 5 minutes. They are now for sale through my website for the low price of $199.99. Hardware and lumber extra. ;)
Step 2 - Insert apparatus into table. Use 10' 2x4's in the 5' table to (hopefully) only have to deadlift 175lbs and slide it at the same time. Put boards down on ground leaving back end of the table in the truck. Yes, the 2x4's are bending that much!
Step 3 - Find some blocking for the legs on the ground, deadlift table up a bit and rest legs on a stable surface.
Step 4 - Reposition apparatus for pushing, rather than lifting.
Step 5 - Apply load to the apparatus, and drive truck forward a few feet. (a second person helps here) Gently lower table feet to the ground. Warning, table is heavy!
Step 6 - Reposition apparatus for lifting again. Lift table and slide out blocking. Set table on terra firma.
Step 7 - Use floor jack to lift up dead end of table, deadlift the other side using the apparatus, and drag it into position.
Next steps are to cleanup and refinish the table! Though, the rest of this weekend will be spent working on the garage rather than the table.
Z
Zengineer
OK, going through some lighting calculations for this space... I had screw in plastic bases and 60w bulbs around, so that's what I've started using. 8 were installed, but with the understanding that they wouldn't be the permanent lighting solution. These are represented by line 1 of the table attached.
Still haven't decided what the final fix will be, though I'm leaning towards the T8's.
shopnut
Florida
With my weight, I would have been catapulted into the next county :)
I do 99.9% of my projects alone so I am glad to see you came up with a method to get this off the truck with just a little thought.
Z
Zengineer
Well the photo was staged, but not far from the truth. When it was done for real, my help and I lowered it together. I was 1/4 the way up the boards for this photo, if I was all the way at the end of the lever I'm still not convinced I could budge the table.
Z
Zengineer
Some more garage progress today... it's getting so cluttered in there since nothing has a home and I'm working on the walls. Pushing ahead and finally got the drywall mud to the point I am ok with it. To be honest, it turned out better than first expected, but I'm not going to make a living doing that. Next time I have a project of any size I'll be hiring someone. I'll stick to patch panels and so on at most from this point out.
It sure feels great to get some primer on the walls. In addition, I picked up 10 sheets of 1/8" hardboard last night, so that I can do the base in that to protect the drywall. I might find some time this week to get going on that.
Z
Zengineer
Hardboard (Masonite in the U.S. I believe) is starting to go up... going to paint it a medium gray to hide the dirt a bit. Started with using drywall screws... couldn't drive them in hard enough to sit flush, so going to use deck screws for everything and then paint over them.
Removable if necessary for replacement, but in reality it should provide all the armour necessary for the drywall for a very long time.
Also picked up some 2" wide moulding for on top of the hardboard... I think it's going to end up toolbox (fire engine?) red. Should provide a nice visual break, as well as protect the top edge of the hardboard. I figured for an extra $25 for trim and paint I might as well.
Z
Zengineer
A few more hours on the hardboard today... paint tomorrow night hopefully.
Decided to go with the medium gray on the door and window trim as well, I will paint the door to match at some point.
Looking forward to putting some stuff in "its place" for the first time, and creating some room in the garage in the process.
Z
Zengineer
Well I managed to find an hour yesterday (hard to do with a 18mo old) and got some paint on the hardboard. Starting to come together finally. What this means is I can actually push some stuff against the finished walls, and create some working space for myself again. That's pretty exciting in itself!
I still have to paint everything above the hardboard (just primer right now) but I can do that with my benches in place, and out of the center of the garage. Then I need to finish the other half of the garage, which is touching the house.
I've left it open to complete some electrical upgrades in the adjacent room, as well as add a door, plumbing (for garage sink), and so on. I need to get the garage into order so I can start on that transition and project.
I've got the TV hooked up in the garage now, which is great for a sports fan!
More to come this weekend with any luck...
UN4GTBL
Looks good!
I like the hardboard idea!
...and the trim will make for a nice transition.
49stude2r6
Bremerton, WA
Your sweat equity is paying off nicely. Adding the garage to the house was a big improvement, finishing the garage is turining out very nicely. I like the functionality you are building into the place.
Z
Zengineer
Switched out the Philips Natural Daylight incandescent bulbs with some Philips Daylight Mini-Twister Florescents this evening. The jury is still out on the color temperature. The Natural Daylight bulbs are in the 3800K range, really nice light. The replacement ones I installed are 5000K.
Takes about 1 min to get to full brightness, but going from ~18foot-candles up to ~33foot-candles makes a big improvement in overall light levels.
Once I actually paint the walls (bought paint this weekend) I expect a bit more reflectivity as well.
For $20 to nearly double my light levels, I figured I couldn't go wrong...
Z
Zengineer
After living with the mini-twister CFL's for a little while, I really do like them. The 5000K colour temperature has worked out just fine once I got used to the change, and the light levels are certainly much improved (doubled almost). Going to call it quits on lighting upgrades for a little bit, this will tide me over. I now have about $35 into my complete lighting solution!
ct96ek
The transformation is exceptional! I can't wait to see it all put together with the Z inside :thumbup:
Z
Zengineer
A new addition to the shop today...
Pratt & Whitney 12x30" (though it will swing 14.5") Model "C" with DRO...
VFD on the way. Might be a couple of weeks before I really get it going, lots on my plate right now... but I can pick away at cleaning it up, wiring for VFD, taking some inventory of what is with it, and unpacking it/leveling it.
Have the original manual, and also the original sales pamphlet with it. Pretty neat to see! I'll get that scanned for perusal sometime soon.
reddog289
Detroit
After reading your post, I wish I would have got more stuff from my Uncles machine shop when they closed.I like the way your garage is turning out.
theoldwizard1
SE MI
Looks great !
One minor nit. I would have put the wall outlet on a 12 gauge 20A circuit. You can run a fair size compressor or a good table saw easily on a 20A circuit.
In my neck of the woods, all garage outlets must be GFCI.
Z
Zengineer
Good comment... I have a couple larger capacity plugs on the other side of the garage, wired next to the panel. 40A 220v welding plug, and a 20amp 110v plug.
My air compressor is in an insulated self-contained building about 20' behind the garage. Great for noise reduction. ;)
This was always planned to be a fix & sell house, and while I haven't cut corners, I've been pretty cost conscious when it comes to renovations.
Square2.0
Your garage looks real good. I like the 240z you got. I really want to build one of those up some time.
Keep up the good work.
