Snap-on Wrench organizer question
gc11090
I am looking at the snap on wrench organizers, either KRA15A or KRA22A. The 15 says it is for smaller wrenches, where the 22 says it is for larger wrenches. I have 2 standard sets of gearwrenches in the drawer that I will be using them in, about 8-19mm in size, does that classify as a small wrench or a large wrench? If someone has pictures of the wrench organizers in use that would be even better.
CBradio
Hampton Roads, VA
I fit all of my wrenches up to around 1 inch in the 'small' size holders. Gearwrenches have a pretty thin beam on them so the will fit.
dsan
The large wrenches are from the snap on truck. The small ones are from a aftermarket co.. I can check tomorrow for the brand if you like
Vinko
Los Angeles
I got a few that look exactly the same, but branded as Blue Point. They were $10 off the truck. Not a bad SO tax, really, since having to go somewhere that may or may not have them to save $3 wouldn't be worth it to me.
Fedwrench
Valley of the sun
They look like the Ernst Mfg wrench organizers
The Snap on ones are different. They aren't as tall as the ernst versions. They are also alot longer at 24 inches. The Ernst ones are also made of a more brittle plastic. I use the KRA15A for most of mrenches up to 1 1/4 without any issues. The rails can be easily trimmed to fit most drawers. Much better than wrench racks unless you want to be able to haul a whole set somewhere.:beer:
GeorgiaHybrid
Extreme NW Georgia
They work very well and can be cut to length as required. The first drawer pictured is my metric wrench drawer and if you look close, there are several that have been cut down to fit the wrenches and space.
Metric wrenches
SAE wrenches
G
gc11090
Thanks guys! I have the earnest ones for home because I usually put out a set and put it on the roll cart, but I never pull them out at work, so I think these will work great for me. I will add them to my order.
