I haven't done a post on the Pepsi machine as yet but there are some questions I'll answer which might be helpful.
This is the old Pepsi machine in it's normal place for as long as I can remember.
When I started frequenting the shop in the early 60's it cost 10 cents and then eventually 35 cents.
When I bought the shop, the machine was still there, still stocked with soda pop, mostly Pepsi, Mountain Dew and root beer, my personal favorite. It still had change in it from who knows how long ago, still chilled to 38 degrees, worked perfectly and would still make correct change. It is a Vendo 56 but as with most items out there, was cosmetically challenged.
While restoring the shop it was moved to the 2 car garage awaiting it's own restoration.
At present it has been moved to the barn...
... still waiting it's restoration. Mechanically it's perfect, just needs some TLC and cosmetic work.
While restoring the shop my time was limited. Since the Pepsi machine is so central and visible I wanted to have it up and running as quickly as possible. As you might realize I just can't do something half-hearted. When that machine gets redone, it will be done to a high standard. In the meantime I had located a Vendo 57...
...which is a couple of years newer but externally the same dimensions...
... and also holds 7 bottles vertically. While being the same in size it doesn't resemble the old one in appearance. I keep it stocked at all times with a wide range of pop from a store about 20 miles away that carries over 50 different kinds of soda in bottles.
This machine is a gem as well. You can't hear it run, chills to 38 degrees but I have it set up not to take any money. I want my friends and guests to help themselves. Whenever I've given tours and we go through the 2 car garage I've had a couple of "so that's where the old Pepsi machine went, I was wondering". I didn't know that there was any question about the one in the shop being a second machine.
Looks like that won't work as a test question now will it?
Got more coming tomorrow so check back. Happy New Year everyone.
Thomas
