Problem - slow starting air compressor
sigtauenus
This is really weird. Video is about 1 min long. Shows how the air compressor will kind of "wind up" as it is going. It starts right away but has a really slow rpm that builds gradually. It almost seems like its not lubricated but the sight gauge shows it is full of oil.
Compressor is a Campbell Hausfeld VT627505AJ. 60 Gallon tank, 230V, 3.2 HP.
It is about 2 years old and has previously worked fabulously.
As you're watching the video, there is some noise from the motor but you can kind of tell the clunky slow start of the compressor about 15 seconds in, particularly as it starts smoothing out.
Any ideas? I bought it at Lowes, and am tempted to scour my desk for the receipt and take it back and exchange it but if the fix is reasonable I'd rather just fix it than haul a big a$$ compressor to Lowes and back.
nissan_crawler
Wichita, KS
start capacitor would be my guess. Have you cracked loose the air line between the pump and the tank check valve to be sure the pump isn't starting under load?
sigtauenus
I have not. Clarify what I'm looking for? If I hear a hiss that means the pump is under load, right? Would that be a bad check valve?
This just started about a week ago when it got really freaking cold here.
nissan_crawler
Wichita, KS
Correct. The way *most* compressors work, is that there's a check valve between the pump and the tank. However, this obviously still leaves pressure in the pump when it shuts off, so the pressure switch usually has a bleed off valve on it, that bleeds the pump pressure off for a few seconds when the pressure switch shuts the motor off, then the valve closes again.
It's possible that valve on the pressure switch isn't working either, but...I assume your compressor has sat for a while before you've tried starting it, in which case, the pressure would still have bled off (albeit, slowly).
Most motors have a start capacitor on them to help them get up to speed, so I'm guessing it's either that, or the check valve is leaking, and letting tank pressure back into the pump.
airbuff101
Is it in a cold garage Sig? Did you notice the problem when temps recently dropped? Does it reach speed as it warms up and runs a bit? It's a pretty common condition in cold temps from thick earl. :)
My old Sanborn will trip the circuit a couple times a year when chilly. Same symptoms.
I agree that junk/flakes in the check valve will do it too as pump is pushing against tank pressure if it doesn't seal.
Rob
Hiball
Missery
Very Well Described NC.... I had a similar problem and after some testing it ended up being the Starting capacitor, Just took the old one off and matched it up at the local small engine shop.
sigtauenus
Yes, its in an uninsulated garage. And yes, the problem started a week or so ago when the winter storm hit the east coast.
I recently changed the oil too, it had gotten pretty dark in the sight glass, and I replaced it with 30W non-detergent oil, same stuff I use in my generator.
sigtauenus
Thanks for all the quick replies gents.
Is this starting capacitor a motor part or pump part? I assume its on the motor.
nissan_crawler
Wichita, KS
It's possible it's the oil, but that being said, our compressor was left on 24/7 for 20 years in an uninsulated shop that saw -30F, and never had an issue. Even worse, I'm fairly sure that oil was maybe changed once, if at all.
If you want to be sure, drain the oil and put it in your house for a while. Then fill it up quick and flip it on. Hey, it worked for Model A's.:thumbup:
Ben Buck
S. W. Ohio
Is your wiring on a dedicated, at least 20 amp circuit with nothing else trying or working at the same time? Not aluminum wiring or some old, old wiring? I would check the check valve, located, where the dump tube feeds the tank, this thing could have partially let go, releasing pressure back on the head and not letting it start, if it does go out it will not start up at all?!
sigtauenus
Thanks again for the replies.
Found the capacitor on the motor. Actually looks like there is two of them, one is white, the other black. I have a neighbor who is an electrician so I'll have him come over tomorrow and test it for me. He'll probably also know of a local shop where I can replace the capacitor if its bad.
Jbullfrog
Avoca, Iowa
Most compressors use 20w oil, which would be thinner than 30w. My contractor compressor won't start when it is cold, but if you carry it in the garage it fires right up.
airbatica
I would also check the bearings in the motor. The grease may not be up to the cold temperatures.
Warrenator
Newberg, OR
My compressor did almost that exact same thing. Replaced both capacitors on general principles, no fix. Cleaned the centrifugal switch, bingo, problem solved. You can google how to find it, but basically if you pull the end cap off the motor you will see a switch that is activated by weights swinging out as the motor spins up, you can clean the little contact areas by dragging a piece of alcohol soaked cardstock (I use a business card) between the contacts. Note the carbon and grease on the paper. Do it again until the paper is clean.
hofferwood
DownRiver Michigan
Your "caps" are fine.
Try pouring some of that 30w oil into a cup, at 15deg. F.
Like honey, aint it?
I changed to synthetic, Got tired of using a "heated dipstick"
Search "compressor oil" You'll find a ton of info.
Watching your vid the check valve is ok too.
Chuck
toolz
Idaho / No. Calif
Unloader valve: When the set pressure is reached, and the motor is shut down,the unloader releases pressure on the pump (upstream of the check valve on the tank) so the motor/pump doesn't have to start against pressure.
It's the first thing I'd check....
cnc-me
MI
The oil is to thick for the temperature you are running in.
Head unloader is working fine, you can hear the air being relieved.
sigtauenus
Thanks for the replies.
Been busy and out of town. Several cheap or free and easy suggestions. Still need to check the capacitors, will also clean the centrifugal switch and try some synthetic oil.
If I go synthetic, should I also go to a thinner 20W?
bjkulawi
Raleigh, NC
Side note, but it looks like you still have the plug in the oil fill hole that came with the compressor. Mine had a small breather to replace that plug when I unpacked the compressor.
MN_RIDER
MN
Yes, this is an old thread but I figured I'd put my findings here seeing as it relates.
Earlier this summer I started to notice my Campbell Hausfeld compressor model VT639000AJ(60 gal, 240v) was running slow and seemed to labor. Turned out to be a loose belt between the motor and the pump. It didn't squeal, smoke or give any other indication that it was loose. Anyway, after tightening it up it now running like it did when it was new!
Hopefully someone else will find this helpful.
Kenskip1
Missouri
Before we all start tossing suggestions around, how about draining the tank of all air.Then start it and see what happens! Sounds like a bad pressure switch to me.
m4rked1
Acknowledging this is a very old thread, but this result is one of the top links when searching this problem on google. So I figured I would chime in and report that I had almost the same problem, and mine was fixed by cleaning the contacts for the centrifugal switch as mentioned above.
Upon doing a little research, this switch is used to connect or disconnect the starting winding on the motor. If left malfunctioning, the motor will never reach full RPM and actually consume much more electricity while running.
