larrylwill
- Joined
- Mar 30, 2007
- Messages
- 45
I have had a BonAir mini split 18000 btu heat pump system since 2007. I installed it myself in my office, separate building. This past summer it started freezing up on the condenser, inside. It would cool ok for a couple hours but slowly freeze up. I put an indoor/outdoor thermostat on its output.
I would get 20 degree difference when it was working before it would freeze up. I would turn it off until the ice melted then it would be ok again for a couple hours.
I figured it was low on freon, which means a leak, I figured I would get it looked at next spring. However since it has turned cold I have been running the heat pump, even down in the single digits and it works perfect. Of course it has to defrost when its in the teens and single digits but it warms the office just fine. 25-30 degree temp difference. So now I figure maybe something wrong with the reversing valve. Tonight I turned on the air and its only blowing 12 degree difference.
Any Ideas what the problem is?
