Dolfan
OK, I've always wanted to understand better how you determine the electical capacity of you home service panels. Obviously the "physical" capacity is do you have space for breakers to be added.
I'm considering to add a 240v 20-30A garage heater and want to think through the capacity issues.
I have a newer house with what I believe is a fairly large capacity for electrical power. From the "street" I have two 150A panels with a single 150A breaker in each. That then feeds two panels in my basement, I assume each is a 150A rated panel back to the panels outside.
So for each panel how do you determine the current load and capacity? I have tons of physical space but how to know when you are at the limit of the electrical load?
Thanks.
Thanks.
