adding sink to garage
jlcn2golf
I want to add a sink in my garage. The wall for it backs up directly to the laundry room where there is an existing sink. But, the house is on a slab. How do i access the pipes to to tap on for another sink. and then route them across the laundry room thru a wall to the garage.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Are you saying the water pipes are in the slab now? Can you remove the drywall or whatever wall covering is behind where the new sink is going to go to be able to access and tie in? the reason I ask is that the sink in my garage backs up to the laundry room. The wall covering was removed, the pipes were tied into along with the drain, re-sheetrocked,, then shutoffs added. A little tape and mud and you are done.
J
jlcn2golf
Thanks, JC23. My pipes are in the slab. The laundry sink has pipes of course, & are located across the laundry room floor, so the garage connection must cross this floor. I suppose across the ceiling or under the flooring which seems like a very big and complicated job. What do o think??
J
jlcn2golf
I misunderstood who replied to my post. Thanks, Kevin54-any further ideas on how to do this project and keep demolition and cost down?
