source of electric cut off
blanch53
I have found many air operated cut off saws, using the 3 inch wheel with 3/8 arbor.
I would prefer an electric powered model, has anyone found such an item, no luck searching on the net.
1320stang
Edmond, OK
I used to use a Makita die grinder with a 1/4" collet for a cut off saw. I bought a attachment for a drill which happened to be 1/4" and chucked it up in there and went to town. Bad part, it only turned at 18,000-20,000 RPM and it had no guard, so you had to be careful on which way you 'aimed' it.
