Slotting cutter vs straight router bit
bchee
Texas
Which would you guys recommend for cutting grooves? A slotting cutter or a straight bit.
I think I'm going to cut about 50 linear feet in poplar.
I know some of you have done your own garage and kitchen cabinets.
Kurt4440
Western New York
Do you have a router table?
You gave the length, how about width and depth.
Do you have a table saw?
What are you making?
A_Pmech
IL
Depends on the orientation of the slot. :)
A straight router bit works well for slotting the face but not on the side.
A slotting cutter on an arbor works well for slotting on a side but will not slot on the face.
bchee
Texas
I dont have a table, but I was thinking about making one.
I was going to make frame and panel doors, so I want to cut grooves for the panel.
I'm guessing the groove will be 3/16 or 1/4
bchee
Texas
Not sure I understand this. I'm cutting 3" wide by 3/4" thick strips of wood, so cant I position them in any way I want?
metal1313
clinton NJ
slot cutters work better on the sides of stock, while straight bits work better on the face. i have tried to use a stright bit in a table and i did not get the same results with trying to slot the narrow side
Bigpigdave
Camden, IN
Do you have a table saw? I would use a dado to make the slots, much cleaner and faster than a router.
JMHO, Dave
PassnThru
Bowling Green KY
JMHO, Dave
There's your answer. For a simple slot, a table saw is great. You don't even need a dado - multiple passes will do it. For a profile, the router is the best. Routers can be a serious pain when cutting slots or grooves of any kind. You better have a very good, very sharp bit (and spares) and a very good router table for that.
Don't confuse a router and a table with a shaper.
TDITS
Central Missouri
If all you are doing is cutting a slot I'd just use a table saw. That's the way Norm always did it. Make one pass, flip the stock end for end and make another pass. Your slot is automaticly centered.
But if you are set on using a router I'd go with the slot cutter. It cleans the grove out much better than the straight bit. With the straight bit you'll have to go slower and maybe make a couple of passes with it. But if you don't have a router table you aren't going to have much luck with either one.
A_Pmech
IL
You might consider a frame and panel set, such as:
http://www.cmtutensili.com/show_items.asp?pars=RBSET~8/900.512-13-14-16~2
Similar sets are sold at places such as Home Depot or Lowes. They allow you to make all the the rail, stile and panel details. You'll need a suitable router table to make best use of the set however.
bchee
Texas
I'm not set on using a router, but I definitely dont have or want a table saw taking up space.
I also dont want any fancy profiles, just a very basic square frame with all square edges.
thanks for the input guys. I'm going to look into these slot cutters more. I wasnt aware that clearing the grooves was that important.
