terabyte
About 1 out of 10 times when starting my 2008 Ford Ranger 2.3 with 46k miles the engine has to turn over a few times before it starts. It normally starts on the first crank.
Its the original battery which I had tested by the auto parts store with one of the nicer Midtronics testers. It tested within one CCA of the spec of the battery.
I do live in south Florida, so batteries don't last here long at all.
This morning I figured I would do a little test.
Battery Voltage is 12.69V
Charging voltage is 14.14V at idle
Its 70 degrees outside. Snap-On MT 2400 says that while cranking the engine over the voltage goes down to 7.32V. Fluke 87 set to record min and max says the voltage goes down to 9.8V. Both read the exact thing with the truck running or off.
I'm guessing that I'm not giving the fuel pump any time to prime and build up pressure is the reason for the occasional hard start (3-5 turns before it starts). What do you guys think?
Secondly can someone intimately familiar with the Snap-On Mt 2400 give me an idea of why its readings are so off from the Fluke when reviewing the low spot of the histogram?
