NinetyTwoFifty
Just wondering, can the Dual 80 take the extra torque of the long handle? I always thought the 936 was a stronger design. Is that true?
I like the 936 but I don't think it was Snap-On's strongest ratchet.
just curious, what do you think is so's strongest?
The dual 80 ratchets are the strongest ratchets that Snap-on has made. There is more surface area of engagement between the pawl and main gear than any of the previous designs.
i had a shlf80 that i was jumping up and down on to try and break loose a 1" bolt
sheared the drive head off flush with the coverplate, gears were still smooth as silk though, theyre damn strong
Are the 936 ratchets still available? Im loking for a tf 936 and would just buy it new if they are available.
i fixed 936 1/2 ratchets weekly.
the pawl broke real easy.
the 830 could take a beating, but when it broke it would take out 4-5 teeth at once and usually hurt you in the process.....
my tank guys have done that to a couple of 80 tooth the 830 and 936 series shave off all the teeth in the head long before they could break the 1/2 drive off.
