jocool1585
- Joined
- Nov 23, 2008
- Messages
- 142
I have a PVC sewer line running from my detached garage into the line in my house that has never been hooked up. It is about a 30' run and goes under a paver sidewalk and some landscaping. The garage was partially finished and the water and sewer lines were ran from the house to the garage, but never tied in. The sewer line is full of groundwater, so I assume that a fitting has failed somewhere in the run. Rather than dig up the line, I'm considering sleeving it it.
Has anyone here ever used a three or four inch trash pump intake hose inside of an existing line? I would sleeve the existing line, and use the threaded ends to tie into the existing PVC. Seems like a low-cost, rigid, solution to this issue...
That pipe is barely underground... its broke. Push the snake til it gets stuck (make sure you're not just catching on fittings). Mark the snake and measure the distance so you know approximately where to dig. Dig it up and fix. It will be much cheaper (probably 30 bucks) than buying that sewer hose that you wont be able to push through anyways.
