Hey everyone. I'm new on here. Looking for advice and ideas. This is my first home so this is all new to me.
It's a new construction that we bought about 6 months ago in Northern Nj. The garage is 21x35 of 2x4 frame insulated and sheet rocked. Its attached with one common wall of about 30 feet. The rest is exposed and faces north. Ceiling is 2/3rds 10 feet high and the remaining 1/3 is 13 feet high. Ceiling is also sheetrocked and insulated 2x10s with an attic above. It has one 9x7 insulated garage door and one 16x7 insulated door. Has 2 double pane insulated windows 55x34. It sits on concrete slab. Right now it isn't heated and stays about 15 degrees warmer than outside. I am surprised at how cold it is but without a heat source I guess it makes sense. I'm not looking for 70 degrees in the garage. I work in shops and having cars and tools at about 55-60 would be perfect.
I've used the Hydronics explorer to the best of my ability and came up with heat loses of 15k to 25k btu depending on varying outside and desired inside temps. I am not sure if there is a standard temp to use for either one of those.
My original idea was to go with a hanging Big maxx heater but after talking it over with a contractor I felt it would be opening a can of worms. I am trying to stay under the radar with my garage build up and going for permits and trying to stay away from Plumbing, building and any other inspections is preferred. Next idea was to go with either baseboard or a hanging hot water Modine heater on an additional zone off my house heat, which led me to the Hydronic explorer. At this point I and going to try to see how much headroom I have left in the boiler to see if it can handle the extra zone. In the future I wanted to finish my basement and that would need a zone as well. I was told to measure the length of active fins of my current baseboards then multiply that length by 580 and compare that number to the IBR of my boiler. I don't know exactly what that means but will look into it.
If anyone can chime in if there Is anything I am overlooking or with any suggestions I'd appreciate it. Thanks
