Air Body Saw Blades
TxDoc
Wondering if there are higher quality blades from someone like Milwaukee or are they all about the same?
PoorOwner
CA
want to know as well, i have the HF body saw, the saw works fine but I had gotten the blades from HF, they aren't that cheap and don't last very long at all.
chad s
Baltimore, MD
HD sells some made by Blu-Mol, they are USA made, and are better than the cheap Husky branded ones. I break the blased before the wear out, generaly from hitting braces and such on the backside of the pannel.
jimmycrackcorn
Brooklyn, NY
Yeah i have a IR body saw, just bought some blades from mac, and they just don't last too long, the ones from mac i think they are too fine in the teeth pattern. I have a sawzall, which i can chop a whole car up with, and still wouldn't have to change the blade.
T
TxDoc
Thanks for the replies. I am going to be passing by Northern Tools this week and will check out theirs and some IR brand.
toms73novass
grand island, ny
try some good hacksaw blades,that is what i use in my airsaw at work.
I do the same and trace on original blace and use a grinder to shape it like the original if necessary to do tighter turns. If is just mostly a straight cut I just cut the hacksaw blade straight. You get 3 per blade and work well.
