Clean Screwdriver Handles
dodge610
North Canton Ohio
I keep on getting a white chalky film on the handles of all my screwdrivers anyone know what i can get to clean this off and keep it off this is a real pain in the a## and it makes my screwdrivers look like hell:thumbup:
Tavy
I still just wipe all my tools down with a light oil or CLP.
Handle's, especially Acetate, I'll clean off with just a soft rag. Some people really don't like everything having a film of oil on it, though, so you might not appreciate it. It's a requirement up here in the rust belt.
re: Brake cleaner is kinda rough on most plastics. For shame, they oughta toughen up and get with it! It's the real man's hand cleaner, after all. And after shave.
[edit] What you're describing might be the plastic degrading (seen it on stuff soaked in WAY too many solvents, it killed my Xcelites. Got any pictures?
fordbroncodave
just wipe with a rag when your done using your screwdriver. no cleaners or degreasers.
rsieracki
Chicagoland Area
i like citrus degreaser... .got a good deal on ace hardware brand on clearance for $1 a can a while back, sadly im on my last can, did wonders on my snapon plier handle (whatever dipped coating the use) also use on my screwdrivers
D
dodge610
North Canton Ohio
Brake cleaner? I've never heard of anything like what you are explaining
Surprised me too they are all in my tool box in my tool barn i only heat it when im up there working but it is a white chalky film that makes the handles slick and hard to hold on to i have the moisture collection containers in three drawers of my tool box so that my tools wont sweat in the box but this filmy stuff is real annoying.:)
D
dodge610
North Canton Ohio
I hate to sound stupid what is the CLP you mentioned
D
dodge610
North Canton Ohio
These are all craftsman screwdrivers that i have had for years the made in the USA ones if that is the case maybe i should take them to sears and see if they will warranty all of them.
D
dodge610
North Canton Ohio
I have tried that this stuff will not wipe off with just a rag you allmost have to scrape it off its a real pain i used a scothbrite pad on them the last time it cleaned most of it off but came right back in about 2 to 3 weeks.
Kirbot
New Jersey
I'm sure they would, but trust me, you don't wan't them to.
The newer standard Craftsman screwdrivers are awful.
The metal is WAY too soft.
D
dodge610
North Canton Ohio
That is what i was worried about when i first thought of doing that so that is why i would like to get something to clean em up once and for good if possible.:headscrat
Kirbot
New Jersey
I've cleaned mine in soap and water with a wire brush.
If it comes back that quickly, you might try spraying it with clear coat.
I don't know if it would work, but it would be worth a try.
D
dodge610
North Canton Ohio
I could try that or the citrus cleaner someone else mentioned :)
need more tools
your moisture collection containers could be causing this.Have you ever seen the white chalky rings that will devolpein tupper ware or plastic food storage containers? that is calcium.Ive seen it happen to fishing lures tools and many other things.
D
dodge610
North Canton Ohio
THis started before the moisture collection containers that is why i put them in there but ill take em out just as a test once i get them cleaned up now i just have to figure out what to put on the handles to keep it off any ideas.
need more tools
It could be from anything but Ibet that it is calcium because it it a b@!#h to get off and sounds like what I have seen many times and have been told was calcium.I have been told it is from moisture reacting with some other type of chemical. or cotaminated water good luck with it.I hadt to dump some old fishing lures my dad gave me becausce of it cotaminated my box.
D
dodge610
North Canton Ohio
Thanks so far that is the only thing it seems to be getting on so once i get it off ill oil the handles and get rid of the moisture collectors as a test i may just wipe everything down with a light oil to keep it from rusting from moisture see if that stops the problem.:beer:
Hammer1963
Kentucky
Clean them with soap and water, then use a plastic prep cleaner used for painting plastic body panels. Then spray them with adhesion promoter. This will remove the contaminants and open the pores of the plastic allowing the base product of the plastic to re-flow, thus creating a new brite surface. If you try this, show us the results
mikester
small town NY
[edit] What you're describing might be the plastic degrading (seen it on stuff soaked in WAY too many solvents, it killed my Xcelites. Got any pictures?[/QUOTE]
Thats funny...I have the same on my Xcelite nut drivers too. Just them. And they have a strange smell to them. Almost like smoke. Everythings in the same box and theyre in with some cheap Husky metric drivers in the same drawer.
Tavy
Cleaner, Lubricant, Preservative ..cleans, lubes, protects! It's a fancy-shmancy mil-spec (MIL-L-63460) for lubricating guns with, but I've used it with my tools (used to use lanolin oil) with great success. Still no rust, even on the pock-marked chrome. It sticks on well and doesn't leave a nasty coating that things stick to.
Usually find it under the BreakFree brand, although there's plenty of other manufacturers that have something to the same spec. It doesn't wash off easily, though.
Yep, only the Xcelites seem to do it. My dad's collection from his Xerox days are the same way, they smell very peculiar - far back as I can remember. Some things react badly with the acetate, but a light wipe with acetone will leave them shiney and looking new again.
MrMark
Southern Cal.
Dodge, I'm afraid you'll just have to live with that white build up. I don't know what it is, it might be calcium, but I tend to doubt it. It appears on the older craftsman and xcelite drivers that I have. They usually stink like puke too. I've scraped it off, or even scotchbrited in off, and it comes back. Nothing safe chemical wise that I know of will touch it. I suppose lacquer thinner would get it off but it would probably eat the handle too. I think it has to be scraped off with a bondo spreader or your fingernail. The xcelites are from the early 80's.
Underdog
Treasure Coast, Florida
I've seen it on old craftsman screwdrivers stored in my tool box. It looks like white mold buildup, and yea clean it off and it returns.
D
dodge610
North Canton Ohio
Exactly so im not the only one it only gets on my craftsman screwdrivers i am gonna try what Hammer1963 mentioned see what that does ill post pics and let you know how it works maybe !!!!!!! that will do it who knows :)
Busted Bolts
NewEngland
Not only have I had this white stuff on some of my SO handles, but it shows up on certain grips of my mini electrical pliers (mostly rough texture handles) and this is in a climate controlled shop. I think it might have started after I wiped down some of them with WD 40 a while ago.
D
dodge610
North Canton Ohio
I ordered and recieved the plastic prep waiting on the adhesion promoter so i can post some before and after pics UPS sent me a e mail said the adhesion promoter was supposed to be delivered yesterday did not recieve they are usually right on maybe monday cant wait to see the before and after goin to have to give them there own drawer if they come out real nice just so i can show em off white chalky stuff loses i win i hope:thumbup:
D
dodge610
North Canton Ohio
I just tracked my UPS order adverse weather conditions in indiana have it now coming on Monday guaranteed ups never lets me down fed ex has dropped the ball more times than i can count.:)
D
dodge610
North Canton Ohio
Re: Clean Screwdriver Handles Up Date
Here are some before and after scrubbing the screwdriver handles still have to plastic prep them and adhesion promote them but so far so good thanks to Hammer1963 for this idea ill post pics after each step.:)Screwdriver 002.jpg
Lump
Jamestown, Ohio
This stuff is definitely plastic breaking down. That's why you get the odor. The original solvents are still migrating to the surface, and the plastic handles are simply deteriorating...albeit slowly.
I am an antique fishing lure collector, and we deal with a lot of this on lures...especially older lures. In the 1930's Heddon came out with their "Spook" series of lures, all made from a plastic called "Tenite". It was the new whiz-bang material for a while, until time began to reveal its weaknesses. It is not uncommon, when you find an old tackle box with some old Tenite-bodied lures still unused in the box, to open the boxes and get hit with a terrible stink. :sad: And some of the stinkiest lures have literally disintegrated. Sometimes you'll find some new-looking metal hardware, screws, and hooks, in the box, but only plastic crumbs where the lure body used to be. And these extreme cases REALLY stink. :eyecrazy:
Some newer plastics from the 1950's/60's which replaced Tenite also degrade, and when they do they "grow" a white film, which must be scrubbed off. And which will return again in time. Even if they are not exposed to further use, or calcium, etc. Some guys try various waxes to seal out oxygen, but with only mixed results.
But I'm pretty sure this white film is not calcium; at least as far as I know, because it happens to brand new unopened plastics still in their original boxes. I would think that calcium might build up if these plastics were often submerged in water or something (like it does on dinner ware and plumbing fixtures).
It's a PITA, but the only fix I know of is too keep cleaning them.
Mr.Nutcase
USA
Stop playing with tool...........:bounce::bounce:
jmh21586
Pine City, MN
I have an old SXS shotgun with a tenite stock. From the 50's. It always has a scumy white film on it.
MrMark
Southern Cal.
Lump has it right I'm afraid. They look good! How did you abrade the white film off? Scotchbrite? Green or Maroon?
