HoosierBuddy
Hey guys...post title says it all. I just wanted to share some thoughts about Carbon Monoxide and what we need to know about it to stay safe. Hope to hear others thoughts as well.
Carbon Monoxide is a colorless, odorless gas commonly formed by the incomplete combustion of a carbon based fuel (like gasoline, propane, natural gas, wood, coal, etc) with air. It is flamable in high enough concentrations (ever see the movie "BackDraft"?) but that is not it's chief danger.
Carbon Monixide is toxic to humans (and most or all animals as well) as it is absorbed by the blood in place of oxygen and will prevent the blood from being able to carry oxygen. Light exposures may lead to a headache, nausea, blurred vision, lethargy, etc. Heavier doeses can lead to coma, paralysis and death. In high enough concentrations, CO can kill a human in less than a minute.
If you suspect you (or someone else) is suffering from CO poisoning call 911 and seek medical assistance. While a fire department (or your local gas company) may be able to check your house for CO, the only way to know for sure if you have been exposed is to go have your blood tested. In other words, just because the Fire Department's detector doesn't find any CO when they come check, doesn't mean that an hour ago you didn't get a lung-full of it.
Carbon Monoxide detectors are available (at places like Walmart) and provide a good bit of comfort to know if you have CO in your home. I personally prefer the one's with a digital readout compared to the ones that are just like a smoke alarm. Also, I like the plug in ones, as the battery operated ones start going off when the battery gets low leading to a lot of angst by those that own them.
The biggest dangers you are likely to run into in your garage due to carbon monoide are improperly installed appliances (i.e. forgot to install the flue?), faulty heating equipment (cracked heat exchanger), wrong heating equipment (heating your garage with a grill for instance) OR RUNNING A VEHICLE without proper ventilation. I've also read accounts of generators being run inside a garage and causing deadly CO issues.
Something I've noticed is that older cars with carburetors put out one hell of a lot more CO then modern EFI cars...but you can't probably count on that because even an EFI car could have a fault that would cause it to put out a lot more CO than it should.
Besides being a threat in the garage itself, CO can migrate to other attached areas of a home or building and harm someone there.
So...be careful out there. The last thing any of us want to do is poison ourselves or our families. It's a dangerous deal and kills people every year.
I personally don't have a CO detector in my garage...but I do have one in the bonus room above it. I'm curious how many people have CO detectors in their garages and if they do...is that working for you?
Phil
Phil
