8 foot ceiling or 10 foot ceiling?
ineedagarage
The front of my 28x40 garage will be just 40 feet from the back of my house. In order to match my house should I go with a 8 foot ceiling? Or will a 10 foot ceiling garage not really look out of place? I plan on getting a 4 post lift but I will be using scissor trusses so even if I do go with the 8 foot ceiling I will have 10 1/2 in center which should work fine. Opinions would be great thanks.
bczygan
DETROIT! Arsenal of Scrappers
Absolutely as high as you can get it. You are detached. It is a different use. One way to make the scale of the higher garage look right is to use a taller door in the higher wall. Also gives you better access for boats and tall trucks on trailers or vans with tall roofs. It will look great.
ambenz
NW Chicago Suburbs
I had the same issues but decided to go 10" ceilings.
You can always add things to the side of the garage to make it appear less massive.
This pic shows my garage in relation to the house. Took me a while to get use to the difference but now I don't even think about it.
rodm1
Try lifting anything out of a pickup or trailer with a chain hoist or come along and you will won't at least 10ft. if you get a lift 10ft will be low.
kb2tha
Delaware County, NYS
I would go 10' without giving it a second thought. Because the garage is behind the house and in the background, I believe that will help minimize the taller garage.
Ken
PassnThru
Bowling Green KY
It's a detached structure so don't put so much importance in matching your house that you give up functionality. In my instance - I have 8 foot walls that sit on about a 5 inch curb. However, my roof pitch is about double the house so it is taller. So don't forget the roof pitch - it will also determine the overall height of the structure. Mine doesn't stand out even though it is noticeably taller.
Zengineer
British Columbia, Canada
I have a 9'6" garage and an 8' shed... after living with both a bit I'd never, ever build a shop with an 8' ceiling. I smash things into it all the time.
9'6" seems good, yet to hit it.
stingry
Western Nebraska
Here is my shop that I am building. I also wanted the architecture of the shop to compliment that of the house but also wanted a practical shop. Here's an exterior picture
View media item 6761
It has 10' ceilings but due to the 3' overhang, the exterior wall only shows 9'. Instead of scissor trusses, I used coffer trusses for the area over my lift, giving me a 12' ceiling. Coffer trusses are shown below
View media item 7636
As stated above, I do not believe 8' ceilings are tall enough for a working shop. 10' seems to be a good compromise. Good luck with your build.
Cheers
Steve
Bigmac0603
Hell, I have a single story house with a two story garage. The garage dwarfs the house and to me it looks perfect.
Chris
BLUBAYOU
An 8' ceiling isn't good even if you don't have a lift. Many materials come in 8' lengths and the ceiling just gets in the way moving things around (ladders, plywood, pipe, 2x4's etc). I would go 10' (or more) and try to be creative with roof pitch and overhang, door size, etc. If the garage is set back from the house, it shouldn't be a big problem since it will appear smaller relative to the house anyway.
I built my garage foundation a bit lower than my house since my lot allowed it. I have 11' walls, a 9' or 9'6" door height (forget at the moment) and used the same color paint as the house but different siding (vertical board and batten style vs. horizontal on the house). It goes with the house, but looks like its own structure. I built my door from cedar, too, so it catches the eye more than the wall height would.
There are many tricks to make a garage look like it belongs, and sometimes making it look LESS like the house is good. The direction of the roof-line helps, too. Turning it 90* to the house roof may work, depending on your design.
Old Moparz
Newburgh, NY 12550
Go with the higher ceiling or you will regret it. The overhead doors on mine are 8' high & the ceiling inside is a couple of inches shy of 12'. You can change rafter angles, soffit height, or ceiling joist & wall height to alter the appearance if aesthetics are critical to you.
Falcon67
Merkel, TX
With it being 40' behind the house, a 10' ceiling with -say- a 9 1/2' eve may well look the same as the house when looking from the curb. The perspective angle and the distance should make them look close.
Nice hint on the eve drop - my next shop will be next to the house, and I can pick up about 6"~12" from the lot level difference and a 9' even may look like an 8' eve on the house. Add 12" in the main work area with the rafters and bada-bing, 10' ceiling.
tfi racing
Cedar,BC
My last shop had a 10' ceiling and I thought that was great until I built the current one with a 12'...If you are building new,8' is a waste of time and money,go as tall as your budget and zoning allows,you won't regret it.There are many tricks that can be used to make the building blend in better visually.
Packard V8
Spokane, WA
Is there anyone, anywhere who really doesn't think size matters?
I know a Brit who does brilliant machine work in a closet. Would he like to have a bigger shop, of course. If I ever build another house, the freakin' basement would have 10' walls.
jack vines
snorky18
Southeast Tennessee
To the higher is better crowd:
Aside from clearances for using a lift, or engine hoist, what's the advantage (or is there one) of going over say 12-13'?. How do you utilize the extra height?
Question
New England
Heres mine, 10ft ceilings in the garage, house has 8ft ceilings. Remember that the house is usually a foot off the ground so the actual difference is only 1 ft. What I did was make the contractor extend the soffets so that the fascia on the garage matched the house. People have said that it all looks like it was built at the same time. OBTW I do also have a lift... works great...
JMURiz
NoVA
10' will look fine, mine is only 16' from the back of my house and you don't notice...as long as you scale the garage door to match...use a 8' high garage door and 10' side walls.
drooartz
Utah, USA
You will never find someone on this board who will tell you to go with the smaller option -- and for the most part they're quite right. :)
Just to play the other side, I will add in that you really should build your space based on what you need it to do, not just on the max size you can build/afford.
For instance, my current attached garage is roughly 21' wide x 20' deep x 9' tall (8' wall on about a 1' stem wall). If that was my workshop space (with no daily drivers in it), it would be all the space I'd ever need. I'm into British sports cars and motorcycles, all of which are very small. I may some day get a mid rise lift or platform, but don't want a full lift. I can only afford one car and one bike at a time.
The money I won't spend building a larger space I'll use for improving the car and bike. So plan for what you need, but also realize that maximizing space can also maximize the money you spend -- and you may even wind up spending more than you need, money that could be better used elsewhere.
jam0o0
Katy, TX
it's all about what you want to do. if all you do in your garage in park cars then 8' is fine. if you wanna park a truck make sure the door is an 8' or bigger. if you wanna work on cars on a lift then 10' could work. if you wanna work on trucks on a lift then 12' is minimum. if you need to park an rv then a 13' foot door might not be tall enough.
for me i can't do much in a 9'. my trucks (both) are 8' high. i can't even change the tires in a 9' tall garage if it has lights. and it's gotta be 10' ceiling if there is a standard garage door. just to get in.
darkk
Willimantic, Ct.
We did a 30 X30 garage addition with a full second story. Garage inside is 13 foot ceiling with 4 post lift,second floor is 11 foot vaulted ceiling.
Falcon67
Merkel, TX
Take out the lift and my answer is "Not much". Good maybe for storage shelving or picture hanging. I did a lot of work in a 8' tall box no problem. That includes pulling motors, etc. Ceiling height is not an issue with a typical engine hoist. It's also less volume to heat or cool.
Note that for a MaxJax, 8' or 9' is plenty. For something like a BendPak 4 post, 10' isn't near enough. My race car is 54" tall. Add in my 6' 1" and you end up with 11' to clear. Pickup, Jeep, etc - figure 12' easy, maybe more.
I
ineedagarage
Thanks guys for are the help. I will be doing 10 foot for sure. I have another question should I go with a 9 foot tall garage door or 8?
billcole
Northern Michigan
I would go with the bigger door for sure makes it look better. I wanted a 10.5 but it ended up cheaper to go 11.5' because of the stud compared to block cost. My wife did not want the garage to look bigger then the house so she was not happy at first, but after about a month she was like it looks fine. Garages are like tv's they shrink after a couple of weeks.
Charles (in GA)
50 mi south of Atlanta
Tallest door you are comfortable with. There are lots of vehicles that are a tight fit in 8 ft and if you want to back a truck or trailer inside to unload something, that something may not clear the door header.
Height is good, it allows for work space for flipping over long pieces of pipe, wood, steel, whatever you happen to be working with, it also allows for use of a engine hoist, or portable gantry crane (if the crane is 12 ft, you will have less than 10 ft usable since the hoist and trolley hang down from it), you also will have cooler garage in the summer with high ceilings, and more room to hang ceiling fans and lighting and not interfere with your work.
Charles
PAToyota
South Central Pennsylvania, USA
Having gone 10.5' I'd go nothing less than 12' if I had to do it over again. I've got 9' tall doors and haven't really wished for anything more than that. But it depends on whether you're into Porsches or Peterbilts...
38Chevy454
Cincinnati, OH
I have 12 ft high walls, 10 ft high doors. All about 25 ft from the house. My garage is about 2 ft lower than the house, but it looks fine to me. There is enough separation distance that it is not a problem.
stingry
Western Nebraska
I have always wondered why have 12' ceilings and only a 10' door. Other than room for a lift and headroom for the overhead door tracks, is there any other reason for this. Seems to me like a lot of extra space to heat plus the additional construction costs. Not picking on you specifically 38Chevy454 but was just wondering???
Cheers
Steve
bill9860
Northern VA
agree - as high as you can go. To mathc my house I had to go 11'. So I had trusses made that kicked up to give me 12.5'. From outside looks just like the attached garage
38Chevy454
Cincinnati, OH
Cheers
Steve
10 ft high is all I need on the doors, bigger doors is just more heat loss. 12 ft high inside as it was not much difference in price than shorter and I have plenty of inside clearance. It also makles it real easy moutning the OSB sheets on the walls. With regular sectional type doors, you do need some radius for the door to go up and then horizontal. Sure I could have maybe gone 10.5 or 11 ft doors, but 10ft was std size and as stated is all I need. It also has to do with outside appearance, I have a reasonable header space above the doors outside to help balance the look.
PAToyota
Typically higher ceilings inside are to accomodate a lift. So your tallest vehicle through the door is going to have to go higher than the door when you lift it.
For me, my 9' doors accomodate anything I want to drive in, allows me to back the pickup with a load into the garage, and also gives me enough room to carry things into the garage with the Bobcat with the lift arms partially up.
If I had a higher ceiling than 10.5', I'd likely go to a 10' door but I don't see myself going for more than that even if the ceiling was in the 14' to 16' range or higher.
