What do you use for a pitman arm/tie rod puller?
Tom2
My first time ever replacing tie-rods / ball joints on a rusted Ranger. Wow, what a project it turned into..
I bought a simple pickle fork from Harbor Freight. It worked great for the tie rod ends, and even the spindles. But when it came time to remove the tie rod from the pitman arm.. Forget it.
I hammered on it for hours. Then I heated it with my MAPP torch several times. Soaked it in WD40 and candle wax. Kept hammering on it with my 5lb sledge. Wouldn't budge.
So I bought a $15 pitman arm puller from Autozone. Wouldn't even fit. Returned it.
Went to Pepboys and got the $90 OEM brand loaner. It was adjustable. I first tried to remove the pitman arm from the steering box with it, but it didn't fit on very well, so I placed it on the pitman arm/tie-rod joint. Had to get the adjusters super tight, and then crank on it. Took me about an hour. I had very, very little clearance/room to work. Had to remove the lower radiator hose just to have room for the puller. No room to hammer on the pitman puller, no room for an impact. Just barely able to tap directly on the tie-rod. Cranked the puller tight, smacked the tie-rod several times and it all came crashing down.
It felt like a miracle.. I was really getting worried. Thought maybe I'd have to replace the whole steering box and pitman arm. New steering box is about $150, Pitman arm is $80.
Hopefully I didn't damage the gear box through all this. I never hammered directly at the pitman arm.
I imagine the best tool are those cone shaped pullers. Putting an impact directly on those probably makes the whole job almost too easy..
yogitech
Orlando, FL
They can be a royal pain at times. I've had some beat me for a couple hours and others popped right off. You shouldn't have to replace the steering gear and pitman arm unless its binding on turns or has too much freeplay. I don't think you could do any damage to it though. Are you rebuilding the whole front end? lol
T
Tom2
It started so innocently simple. Took it in for a front end alignment. They couldn't align it because the ball joints were so bad. While I was at it I figured I'd do the front brake lines, radiator hoses, shocks, the tie rods were probably too rusted to even adjust, so figured it'd be best to replace them while I was it.
After I get the front end work wrapped up today - tomorrow I'm putting a trac-loc differential in, new wheel seals, and rear shocks.
2 weeks ago I did the heads.
This project never ends :scared:
Atleast it should be like a new truck after all this.
johnsdeere850j
Oklahoma
I like to either unbolt the gearbox and let it hang to get a better angle or pull it out and put it in the vise if it gives me trouble. Heat, good OTC brand puller, and a couple whacks from a hammer on the bottom of the sector shaft usually persuades them. But on some I end up grinding a notch in the pitman arm around the shaft to get it out then I just replace it of course.
Lotek
Los Angeles, Ca.
But it will still be a Ford... :evil:
Unless you really went gorilla on it, the box should be fine, as long as you didn't damage the output seal with the torch. The cone shaped pullers work the best, it helps to smack the side of the pitman arm at the splines with a hammer.
johnsdeere850j
Oklahoma
Oh yeah, careful with heat too its easy to ruin the sector shaft seals in the gearbox.... LOL I get carried away on some and do just that
Bull
I saw a trick written about in an old auto mag.
It described using an air hammer with blunt/rounded tip to be used against the tie rod or similar joint. The rapid vibration was supposed to loosen even stubborn connections.
I can find and scan the blurb for anyone interested.
RLYoung
Arizona
I'd like to check that out.
I have a pickle fork with an air hammer attachment and it works pretty well for me. Aside that, it seems like you did everything in about the same sequence of events I do. Aside for going out the night before and spraying PB on everything and letting it sit all night! Then again, I'm over here in AZ where it's dry and little to no rust.
sselander
CT
I got mine apart with a HF service kit. I bent one of the parts, but they gave me a new kit to replace it
The HF one is $80
http://www.harborfreight.com/5-piece-front-end-service-tool-set-66686.html
My problem was my CV axle was stuck in the hub. Took awhile to get it out.
I noticed Cripe has some NAPA service kits available for $60.
http://www.cripedistributing.com/napa-professional-front-service-41690-p-7786.html?manufacturers_id=271
johnsdeere850j
Oklahoma
The HF one is $80
That napa one might not be bad at all with that warranty
Aberdale
I've used the air hammer method with success. For me it worked better than a pickle fork or a puller.
Techniker
How do those Napa warranties work and are they worth it? I'm a front end technician and our specialty tools have always been provided to us by the shop. However, our manager just left and I see the writing on the wall with the manager who is going to replace him, so I am planning on bailing out and heading to another shop.
Would you recommend this kit for a technician where heading out to Napa isn't a problem if it breaks (this is a side job for me- I can't justify Matco/Snap-On prices)? Will it really handle most/all of my Pitman arm/tie rod/ball joint separations? I have noticed that a lot of places sell specialty master ball joint separator kits (one of the other guys in my shop has one), but what advantage does that really offer? It seems like these do just as well.
Thanks for the help,
Techniker
sselander
CT
I don't know about NAPA's warranty. I did the work on the Chrysler last summer, and when I saw this thread I remembered recently seeing the NAPA kit on Cripe and noticed the price. They all look like OTC knock offs
johnsdeere850j
Oklahoma
They look EXACTLY like the otc set I have... Probably get them from the same factory in China or something.
Techniker
Definitely. I assume they are actually all made by OTC, just rebranded for the company in question. Do you think it should do everything I need it to?
-Techniker
Buckgnarly
VT
I have the NAPA kit, have yet to use it but I can tell you I paid a hell of a lot more than 60 for it. Most of the NAPA stuff is rebadged KD.
As for pitman arms, I finally gave in and got the SO cone puller. Too many NE rusted trucks/Jeeps and broken pullers.
AZ_Catskinner
Morenci, AZ
I've never had a problem exchanging warranty stuff at NAPA. They've had to overnight a couple of items that weren't in stock, but did so with no questions asked.
johnsdeere850j
Oklahoma
You talking about the CJ119B snap on cone puller? I have one, threads stripped out of it and snap on guy wont give me a new one so it just sits... I was going to weld a couple nuts on it and get a new bolt but not yet
Fedwrench
Valley of the sun
The puller on the right side of the NAPA kit is better that silced bread for most suspension work. Unlike a wedge fork, it won't damage boots. To me it's the only worthwhile part of the front end service kit but, that's just me.
Buckgnarly
VT
Yup. I think it's time for a new SO guy, or time to email/call the website.
scott37300
Wisconsin
I just typed my zip code into the napa site and that kits 134 bucks at napa, over double the cripes. The otc kit is only 101 at tooltopia with free shipping. Not sure if it's any better or not. Or how the warranty would work on it but I have some OTC pullers and they are really nice.
D9H 90V
New Mexico
doing pitman arms, ball joints and tie rods, you can beat them or they will beat you, just get the best puller you can get alot of your favorite penatrating oil (pb balster) for me and a 32 to 40 oz ball peen and get to work, but I have broke more then a couple Snap on pitman arm pullers, so be prepared
johnsdeere850j
Oklahoma
Do they warranty you on them SO pullers?
T
Tom2
soak it with some pb blaster, use this very DIY cost effective tool :) and hammer the housing using the flat hammer bit, falls right out. I do big trucks.
http://www.amazon.com/dp/B000NP2R26/?tag=atomicindus08-20
Yowza!! That's an expensive air hammer.
Of course before I bagan this project I sold my air compressor and all my air tools because I wasn't getting enough use out of them :lol_hitti
Living in the North *****. Makes every project twice as hard sometimes.
sselander
CT
glad I could help, I would have gotten it also but I still have the HF one I bought last summer.
Techniker
What really got me was that it was cheaper than the HF version (until I added shipping anyway)! I had been playing with the idea of buying the set from HF for a while. Napa is a lot closer and more convenient for me than getting to HF.
Thanks again for the deal.
