I am planing to build a new 23 x 32 garage this spring with radiant floor heat. My contractor has suggested that in preparing the slab, the Pex tubing first be attached to the 2" floor insulation before placing the wire mesh w/chairs over it. This in part because I will be installing a four post lift and he is concerned that in making cuts to the floor (4" slab) he might puncture the Pex tubing. He has also suggested placing sleeves over the Pex in the areas where the cuts will be so expansion and contraction of the floor will not affect the Pex tubing.
Does this sounds like a good plan?
John D.
John D.
