nandomart
I have Campbell Hausfield compressor from Lowes. It is the 5hp 80gal compressor. I plan on installing the HF auto drain kit (http://www.harborfreight.com/automatic-compressor-drain-kit-46960.html )..after some googling and reading various reviews I figured this may be a simple solution. Also if it doesnt work $10 isn't something that will break the bank.I am planning on doing the install based on this write up:
http://www.paragoncode.com/shop/compressor/
My question is...my compressor as 2 drain outlets, a bottom one and one on the side....where should I install this auto drain kit? Is the bottom the primary or is it the side one...or do both perform the same function?
Thanks in advance.
Thanks in advance.
