Trying to figure on how to run power to the proposed garage. I talked it over with our local utility and it is going to be extremely expensive to run a new drop on the pole to a new meter base. As an alternative I can run a 100amp breaker in the current 200 amp box located in the attatched garage. My question: Is this to much load to put on the box? I run a heat pump so it alone already has two 60 amp breakers in the box. I don't plan on welding but I may want to run AC and or a pool pump in the future. It would be a 150' run from the current box to the one in the garage. What kind of wire will I need to run that distance or is this scenario just sound like trouble from the start?
