screw VS nail
klhitman
pewee valley
i was just wondering if you guys prefer to screw stuff together or nail it. of course i mean wooded item. i like to screw. seems to hold better:lol_hitti
D.J.
New Haven IL
My vote is screw and GLUE if you are not going to be taking it apart and just screw only if you may be taking it apart in the future. I've seen way to many nails pull loose.
ishiboo
Oshkosh, WI
In shear and compression, nail.
In tension, screws!
Mostly agree.
I screw all of my workbenches/shelves/etc. so I can reuse the wood later with ease or reconfigure things.
Otherwise, almost all nails since I bought a framing nailer... much faster and a much better structural connection! As you said, shear strength is higher.
dlenkewich
Saskatoon, Sk, Canada
I screw.
Most of my projects are done by myself alone, screws hold together better under tension and at awkward angles don't require leverage and continued blunt force to set in.
MeentSS02
Dayton, OH
I try to use screws whenever possible, but I could see where things like trim would be quicker/easier with a nail gun.
pprince
Trim gets nailed with my air gun but everything else is screwed.
metalbasher
Alabama
I like to use those star, or Torx (I think that's how it's spelled) head screw. They are more expencive, but they don't slip in the bit like the phillips heads screws do.
tomsmith
Agree with pprince and meentSS02. For trim, I use nails through a pneumatic nailer but screws for everything else.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
In tension, screws!
For structural applications which is what I think the OP was asking about I agree.
I find nails easier to get apart than screws when the screw heads are phillips. I hate phillips, I much prefer torx or square drive.
Galvanized and ring shank nails can be a real pain to get apart. The adhesive coated nails used in nail guns can be a PITA also.
slip knot
Texas gulf coast
If I'm biulding for myself its screws. If I'm building for someone else or on my rentals I usually use the nailers. Nailers are much faster and easier to demo when needed. Try pulling a deckscrew out with a prybar.
Falcon67
Merkel, TX
Both. Nails more in structure than screws because nails have a bit more give if the structure moves where a screw may well snap. 15 or 18 gauge nails for trim, screws for most else.
bradleykd
Georgetown, KY
depends on what i'm building... if i think i'll pull it apart down the road its screws, if not i hit it with a nail gun...
ddawg16
S. California
I screw anything that moves. (Which I mean both seriously and as a joke.)
That might explain all the little "Jacks" out there......
Each has it's purpose....
General framing....nail....especially when your using a nailer....
Shearwalls.....nail...
Subfloor....screw and glue...you never want to nail...the screws won't back out like nails can. AMHIK
Any kind of workbench....anything where there is a chance that you might want to take it apart...screw.
Trim...nail....it would take a lot of wood putty to hide those screw heads..
The wife.....both ways.....I've nailed her with a good screw in several parts of the house....
BLUBAYOU
Same as ddawg16 though I have used trim screws on occasion, which aren't too bad to fill (square drive with small heads).
Stuart in MN
Minneapolis
Lots of people use them, but remember that drywall screws aren't designed for structural use - they're quite brittle.
TN_GARAGE
For sure.
Regardless of whether you screw or nail, you've got to use the one that is designed for the job (that's why we all have dozens of bins/jars full of nails, screws, bolts, etc. :))
FWIW, I typically use screws unless its brad nails for very light stuff such as trim.
I've even been known to use both (quickly tacked up some shelves and boards the other day with my brad nailer because I don't have but 2 hands, and then came back with some screws)
djjsr
In the cornfields
If you've ever seen a structure that's been demolished by high winds, you'll notice that the majority of the damage is caused by nails that have pulled out. I wonder if anyone has ever tested the nail/screw difference. Build 2 identical structures, one nailed and one screwed and stick them in a wind tunnel. Any of you guys have your own wind tunnel?
Skin
Boston
screws are far far superior for holding tension. Its the shear load where they lose [usually] and why they arent used for things like framing. It really all comes down to brand though. Drywall screws are terrible, high quality deck/all purpose screws on the other hand can be very robust.
BLUBAYOU
Is the Porsche consider a "thing that moves"?
It's okay to love your car. Just don't LOVE your car!
Jack Olsen
Los Angeles
I draw the line if a pulse is absent or paws are present. ;)
And now back to your regularly-scheduled thread.
ddawg16
S. California
You know how GJ emails you a copy of a response to a thread that you have subscribed to?
Well.....when you get the above two emails without the added context to which they are responding........you very quickly think WTF?
TN_GARAGE
Sometimes its because they didn't nail into the trusses. When you are running down a roof with a nail gun, it's easy to do (and not know it).
3 at 8
N. E. Ohio
I screw.
This is a really good point. I've done alot of projects alone that due to holding things solo, or; your body being contorted at awkward angles, a screw was the only practical option.
6brzina
Forney, TX
I couldn't resist :lol_hitti
I use screws and glue for most projects around the house.
