The Vintage Industrial Look ??
tankwilson
Iowa
Hey guys i am in the middle of finishing the inside of my new shop. I just got done putting up old corrugated gavanized steel on parts of the walls and ceiling. I am going for the old vintage industrial look but i am having a hard time finding stuff. Looking for
Ceiling mounted lights and/or fixtures (cage that goes around the light)
Door knobs
Light switches
Outlets
Misc.
Where does one find this stuff that doesn't cost a fortune?
Thanks
matt
pdham
Harrisonburg Va.
I'm not sure if this will suite the need but this is what I did. There is a big push to replace the metal halide lights (The big round fixtures that hung from the Gym ceiling in high school) in industrial spaces for more efficient LED systems. I have found lots of old fixtures to be had for little or nothing. Just check the ballast to make sure they will work on the voltage you have available in your shop. Many times the ballasts are multi-voltage type. Check with local electrical contractors, or with the maintenance department at local industrial plants. These generally draw 400 watts or so. Expensive if you are running them all day every day, but not bad for weekend warrior. These big lights are great but often take a while to come on, particularly if its cold, so I also installed basic single bare bulb screw in light fixtures that come on on a different switch. I installed florescent flood lights into these fixtures. Now if I go out to the shop to get something or work on something that might not require bright lighting, I use the small florescents, If I'm working on something that needs good lighting then I crank up the big boys. I have a 24 x 60 x12h shop with 2 rows of 5, 400 watt MH high bay lights. Its great when I turn them on, there are no shadows in my shop. The front and back rows are controlled separately so I can only run them in the area I'm working in. The florescent are set up on 3 rows of 5. At 13 watts each I can light the shop with half the electricity just one of the MH lights draw. Needless to say I mostly use the floresents. :thumbup:
5lima30
Mountains of Western NC
Have you considered making some of your own light fixtures? A BBQ restaraunt near us has hanging lights made out of galvanized feed pans (about 4.00 ea at TSC) and hanging with swing set chain. They really look decent for very little $$. Just a thought.
jktruck150
Outskirts of Jackson, MS.
I would love to see pictures of your shop now!! You can make your own light switch plates out of just about anything, just use on of the cheap plastic ones as a template. Maybe diamond plate, mabe rusted metal pieces that you bent the edges over. Just mark and drill the mounting holes for the screws.
Edit: The barn my horses are in, use some exterior switches on the inside. They are gray and have a horizontal lever you move up and down instead of a switch that sticks out. Those might be a nice touch.
Ign
Butte Peak ND
As much as Jack Olsen's garage would never suit me, his light fixtures w baking pans are pretty cool.
Also saw on Mega Dens (the chick is obnoxious BTW) she used something like metal candle enclosures and put an LED bulb in them, then also did some bike chain top and bottom.
zoomzoomjeff
Des Moines, IA area
There's a BBQ restaurant locally that uses galvanized 5 or 10 gallon wash pans that are hung upside down with lights inside, similar to what the poster above described.
In addition, I just saw a ton of those round halide lights on the local craigslist here for cheap. They might pop up here and there as people do replace them.
Actually, I see you're from Iowa. Let me see if I can find that CL find....BRB.
Okay. I found them:
http://desmoines.craigslist.org/grd/2251876176.html
175 watt mercury vapor light fixtures, $15 each. About 40 of them left.
Looks like he used to have 80 of them as of 1-25-11.
http://desmoines.craigslist.org/grd/2179717943.html
Seems pretty cheap to me, but I already have enough lumens in my garage to bug the neighbors! :D On second thought, they are 175 watts. Wonder how many lumens they put out. One can never have too much light, right?
Good luck, hope that helps out.
Norcal
Okay. I found them:
Mercs are so obsolete, it ain't funny....
rwhite692
Central Valley, CA
Door knobs
Light switches
Outlets
Misc.
Thanks
matt
The guys who build the Applebees restaurants
