mikebramel
Dead blow hammers : pass
Black rubber mallet: fail
handle broke when i smacked the sh*t out of it
Black rubber mallet: FAIL!
Stunk up half the garage![]()
did it break though?did it break though?
(Snap On) on it though. So take that into consideration.
Tried a search on this thread, but didnt come up with any hits...
Does anyone have thier 50ft Retractable air hose reel?
http://www.harborfreight.com/50-ft-...ose-reel-with-3-8-eighth-inch-hose-93897.html
Also, does this ever go on those 'super coupon' deals (i dont recall ever seeing one for it) or is the 20% off coupon the best I will get?
Thanks!
Thanks!
Inside track sale tomorrow,
http://widgets.harborfreight.com/ws...c_plsearly.html&cust=78152118466&keycode=0000
21 gal 2.5 hp compressor
http://www.harborfreight.com/air-to...-cast-iron-vertical-air-compressor-67847.html
Pass so far. Using it for 4 hours while I do work on the Blazer. Its good for running nuts but when you use an air hammer you can feel it drain.
I have one, its decent, does the job in my home garage. Gotta pull it a little slow when you want the ratchet to lock, but it works well with no leaks.
I've been looking at that model myself. How quickly does it refill once the pressure switch kicks on if you don't mind me asking? Is it LOUD?
I've had poor results from that generic Chinese air hose. It always dries and cracks in a short period of time. Can't speak to the reel quality.
how has it hold up and work?
Has anyone here tried this welder?
http://www.harborfreight.com/110-amp-220-volt-flux-and-mig-welder-94164.html?utm_source=retail&utm_medium=email&utm_campaign=1011a
15% duty cycle @ 110A for $160 sounds tempting. My little Lincoln Handy Mig just doesn't have the juice to weld some of the thicker stuff.
Where did you find that coupon for $159?
Is the heavier duty one orange?
You guys using your side grinder with the cut-off wheels, should check out the tile guard to use with it.
http://www.harborfreight.com/safety-guard-for-angle-grinders-45921.html
Maybe this is old news but have you guys been to harbor freight lately? They replaced everything with a "pittsburgh PRO" line and are selling SINGLE sockets now. The impact swivel sockets also got rid of that stupid band design and are all steel like snap ons. the new stuff looks really good.
I really like this. Do you know if it works on any brand grinder or just the HF grinder? Is it built from cheap metal so it can flex when you are cutting or is it pretty sturdy and won't bend at all?
Thanks for sharing, I can see this being very usefull for cutting metal or tiles to get fairly straight cuts.
I have one on my grinder with a cut-off blade and love it. I have not tried to use it on my john deere branded grinder yet. It could stand to be a little better material, but it will get the job done for what I use it for.
I assume it comes with the round guard and the foot as one piece? I will have to take a look at it. Would be nice to know if it will fit all brands of grinders or just the HF ones. I have a couple dewalt and milwaukee grinders so don't need another.
Thanks again for sharing.
From the pic it appears that it is two pieces, with the foot held on by wing nuts, so you can adjust how much of the cutoff wheel is exposed.
(Unless you are asking if it is together in one package, then I'll keep quiet)
